Floor Jack Placement
Old Oct 8, 2006 | 07:46 AM
Rich in CO's Avatar
Rich in CO
When jacking up either the front or rear of my truck where should I place the floor jack? Do I place the jack on the pumkin? or just lift one side of the axel and place a stand.
Old Oct 8, 2006 | 08:18 AM
Kwikkordead's Avatar
Kwikkordead
I've used the pumpkin before but don't like doing that. I don't like the thought of the axle tubes holding up the weight of the truck. It probably doesn't matter, but that is what I think. So what I do is use two floor jacks, one under each spring shackle and then place the stands right next to the jacks, but leave the jacks there. The stands are just there for a safety in case one of the jacks fail.
Old Oct 8, 2006 | 08:55 AM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
when i jack up the entire front end, say for installing my lift, i jack on the framerail behind the spring shackle, behind the spring. then use several 2x8 boards in a square to raise the jackstands up some so it's a firm base, and also to make it taller. it is alot of weight hanging over the stands, but it keep the front end entirely open for working on. when i jack up the back, i usually use a 6x6 to shorten the travel of the jack, and i lift by the center of the class-v reciever. then use two jackstands to support both ends of the receiver. i have some pics from my lift if you need.
Old Oct 8, 2006 | 09:02 AM
Uzumati's Avatar
Uzumati
Hadn't thought about that for the rear Kris but the reciever will ditribute the weight evenly to both frame rails
AVR2
Escape & Escape Hybrid
Jan 14, 2016 07:43 PM
fromttt
Jul 30, 2012 05:44 PM
Gage2502
Feb 22, 2011 07:17 AM
ssharber
Sep 19, 2009 09:30 PM
browntown3
Nov 26, 2008 09:13 PM
