Normally the ground wire connector slides down into the hole on the steering wheel.
with the other wire connected to the horn pad.
For the horn to work the ground strap on the rag joint has to be attached.
Then the grounding area on the bottom of the steering wheel is touched by 2 pins.
I'll post some pics for you.
In this pic see the strap on the rag joint to allow steering column to ground to the steering box
Thanks Mil1ion that will help. I just came in and I took the turn signal cam out and found it was a copper or brass button that makes the horn work. I took my test light and hooked the ground up inside the column and the horn blew one time the rest I could hear the relay clicking. So I will pick up a new relay later today.I didn't find a 2nd pin.
We got the horn to work,but the weird thing is that it won't blow if the steering wheel is straight. But if you turn the wheel in either direction and push on the horn button it blows just fine. I guess thats the horn relay?
I have the same problem its been driving me nuts one minute it works next it doesn't but always shows volt on the meter. Just read this and turned the wheel slightly bonk bonk it works. Any suggestions? Relay or is it in the column. Thanks.
First, what year truck are we dealing with? 73-77 use a horn relay that is grounded by the horn switch to make the horn blow. 78-79 don't use a relay unless you have factory cruise control, then there's a relay in the circuit.
Its a 75 f100 4 on the floor no cruise control. I got it working red pn power supply and grounded to the steering cross support. It works perfect now except for dead center.
Thanks for the reply.
