Horns
Old Sep 27, 2014 | 02:26 PM
lewis racing's Avatar
lewis racing
Horns
Heard a f250 yesterday that had a horn like a tractor/ trailer. Are any of you guys adding such a thing? Sounded kinda good. If so how are you doing it? Are you adding a new button for the new horn or disabling the stock horn and making the connections that way, so when you hit the normal steering wheel horn the air horns go off. I have a book that says my horn is over the right front tire but under the fender well. Got to be an easier way than removing all that including the heavy *** tire. Just a thought, may change my mind if to much work. Thanks
Old Sep 27, 2014 | 02:48 PM
Iaff113's Avatar
Iaff113
Have my train horns mounted on the Frame, I have my air compressor hooked to my aux 1 switch and the horn activation is aux 2. Still have my factory horn on the steering wheel
Old Sep 27, 2014 | 04:27 PM
CharlaineC's Avatar
CharlaineC
while i'm not from this forum i own an 1969 camper special. I'm adding airhorns under my hood to replace my inop duel electrics I have a set on my motorcycle and they sound great.
Old Sep 27, 2014 | 06:04 PM
LivingLarge's Avatar
LivingLarge
I love my train horns, don't really use it much but when I do people move...I have it connected so it works with my stock horns but I added a cut off switch.
Old Sep 29, 2014 | 07:39 PM
lewis racing
The train horn you guys are speaking of. Is that the same sound or horn I'm talking about? I'm interested in the tractor/ trailer sound. Thanks
Old Sep 29, 2014 | 07:44 PM
Iaff113's Avatar
Iaff113
This is not ment to be a smart a$$ comment. But the train horns are not and air horn like a big rig. They sound just like a train I have shockers and so you could search them Or Nathan's air chime and hear the sound
Old Sep 29, 2014 | 08:02 PM
Sullid01's Avatar
Sullid01
There are a lot of sounds the air horns can make. A lot of us go for the train horn sound, but a big rig is a single air horn, instead of three tuned to sound like a train horn. Most of the sites that sell them let you listen to sample sounds. The good ones are large and you need to mount them under the truck on the frame. The stock horn is under the wheel well and it is a minor PITA to get to. Loud horns are illegal in some areas so it is good to keep the stock horn and have a separate horn button for the air horn. I only use my train horn for goofing around
Old Sep 30, 2014 | 04:35 PM
lewis racing
Thanks guys, didn't mean to be stupid but when I asked about tractor/ trailer horns what I got was info on train horns. That was the reason for my confusion.
Old Sep 30, 2014 | 07:26 PM
Redrkt's Avatar
Redrkt
These are train horns:
and this is a truck air horn:
They both work on compressed air but make totally different sounds
Old Sep 30, 2014 | 07:45 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Here is a good watch. Hook up horn or horns you like.
Old Sep 30, 2014 | 10:45 PM
Yahiko's Avatar
Yahiko
Onboard Air & Train Horn Ford Super Duty F350 - YouTube
I like. I would add one thing. Auto air/water drain valve.
Sean, are you back home yet?
Sean
Old Oct 1, 2014 | 12:41 AM
amdriven2liv
Sean
Yes, home and back to work.
Mom is getting back on the mend.
Shortlineent
Aug 23, 2009 09:26 PM
mfp4073
1983 - 2012 Ranger & B-Series
Jun 15, 2009 11:03 AM
87wreckerman
17
Feb 17, 2009 06:18 PM
cowboyup11
Feb 9, 2009 07:18 PM
Northguy
1997 - 2003 F150
20
Jan 5, 2005 05:36 PM
