Wish I could help you on the ROMP. My truck had a romp when the engine was warm and it first started up.... ended up being a dieing IDM, However, a romp issue would be associated with a bad IDM maybe 2% of the time, there are a bunch of other things that could be. Wait for someone else to chime in here.
IDM is the Injector Drive Module, It it the computer module mounted inboard of the driver side fender. It's a rectangular silver box and it's bolted in place. It controls the injectors, hence injector drive module. Mine apparently had water in it and was on the way out. For most trucks however, its good or dead.
This question always puzzles me. On every old school diesel engine that we have turned up it smokes blue at idle. They do it cold/warm whatever. Must be the nature of those 404's and 466's.
If your o-rings are going out, it could be a long time before they give you any problems. Mine went out last summer. Not a bad repair either. Just take your time.
Let us know when you do if you need directions, I have a good abridged version kicking around in an e-mail (if your pulling injectors also) just give me a day or two to find it... There are a bunch around here also.
-Robb
Robbgt, I'll take the instructions on the GP and injector o-ring replacements, if you can find them. I'll PM you with my email address.
Id also be intrested in finding more out about the injector o-rings.
The instructions you guys give make some of these things sound very doable................
Craig, got your PM, I'll send you a set as well as post them for anyone looking. Just need to get some torque specs. One tool you may need to borrow (this goes for everyone attempting this project) is a 3/8" drive in/lb torque wrench. Needed to torque down the injector hold down bolts. And yes, you really do need it
i don't know why everyone thinks his injector o-rings are going?? i JUST did injectors last summer and my truck smokes blue (ok it's not like straight blue... more like white when it's cold with a blue tint... but i consider that blue nonetheless) when it first starts up when it's cold for about 20-30 seconds
any diesel motor will smoke when the cylinders are cold, it is a perfectly normal condition. 7.3's are no different, nor are 6.0's they will all smoke. if they blow blueish white smoke on a hot engine then you have reason for concern. other then that ists normal.
