Blue Smoke
Old Apr 7, 2008 | 08:40 PM
PAVEMENTMAN's Avatar
PAVEMENTMAN
Blue Smoke
Is It Normal For A Psd To Blow Blue Smoke When First Taking Off With A Cold Motor.
Old Apr 7, 2008 | 08:44 PM
glasseater's Avatar
glasseater
yes as long as it's not a lot
Old Apr 7, 2008 | 08:46 PM
PAVEMENTMAN
just for a few minutes till i get about 1/2 mile down the road then it quits.
Old Apr 7, 2008 | 08:56 PM
glasseater's Avatar
glasseater
yeah that's about right....
Old Apr 7, 2008 | 08:58 PM
Robbgt's Avatar
Robbgt
Leaky Injectors O-rings... Could fix if you wanted to
onefarmer's Avatar
onefarmer
That's what mine does! Normal diesel. All my tractors blow blue till warmed some too. It's just unburnt fuel due to the cold.
PAVEMENTMAN
I Also Noticed Its Been Taking Longer To Start Than Normal, Any Idea's On That. Still Starts In About 3 Sec But Used To Start In 1/2 That Time. And Its Getting Warmer Here To.
Old Apr 7, 2008 | 09:03 PM
glasseater's Avatar
glasseater
probably bad GPs... ever replaced em??
Old Apr 7, 2008 | 09:06 PM
PAVEMENTMAN
No I Never Did. Would It Still Take Longer If The Weather Is Warm.
Old Apr 7, 2008 | 09:07 PM
Robbgt's Avatar
Robbgt
Does sound like GP's. Also you can fix that blue smoke if you wan to. PSD's arn't SUPPOSE to smoke, but they do when the injector O-rings leak a bit. New inj. O-rings will fix that = no blue smoke
YES gp's do help, even when warm ambient temps... Mine would have trouble starting above 50ºF before i replaced GP's and GPR
-Robb
Old Apr 7, 2008 | 09:18 PM
PAVEMENTMAN
It Was 65 Here Today Would It Still Take Longer. When The Motor Warms Up It Starts Faster.
Old Apr 7, 2008 | 09:22 PM
Robbgt's Avatar
Robbgt
sounds like could be weak GP's if they've never been replaced
ALSO
Here's what you need to fix blue smoke
eBay Motors: Ford Powerstroke 7.3 INJECTOR o-ring
Old Apr 7, 2008 | 09:26 PM
PAVEMENTMAN
Ok. I Will Have To Change Them. Thanks Guys.
Old Apr 7, 2008 | 09:28 PM
Robbgt's Avatar
Robbgt
Let us know when you do if you need directions, I have a good abridged version kicking around in an e-mail (if your pulling injectors also) just give me a day or two to find it... There are a bunch around here also.
-Robb
Old Apr 7, 2008 | 09:32 PM
PAVEMENTMAN
I Will Need Them. I Do Have One More Question. I Noticed When The Truck Gets Warm It Also Has A Mild Romp When It Idles But Not When Its Warm.
