Blue Smoke
Is It Normal For A Psd To Blow Blue Smoke When First Taking Off With A Cold Motor.
yes as long as it's not a lot
just for a few minutes till i get about 1/2 mile down the road then it quits.
yeah that's about right....
Leaky Injectors O-rings... Could fix if you wanted to
Originally Posted by PAVEMENTMAN
(Post 6009478)
I Also Noticed Its Been Taking Longer To Start Than Normal, Any Idea's On That. Still Starts In About 3 Sec But Used To Start In 1/2 That Time. And Its Getting Warmer Here To.
(Post 6009559)
No I Never Did. Would It Still Take Longer If The Weather Is Warm.
Does sound like GP's. Also you can fix that blue smoke if you wan to. PSD's arn't SUPPOSE to smoke, but they do when the injector O-rings leak a bit. New inj. O-rings will fix that = no blue smoke
YES gp's do help, even when warm ambient temps... Mine would have trouble starting above 50ºF before i replaced GP's and GPR -Robb |
It Was 65 Here Today Would It Still Take Longer. When The Motor Warms Up It Starts Faster.
sounds like could be weak GP's if they've never been replaced
ALSO Here's what you need to fix blue smoke eBay Motors: Ford Powerstroke 7.3 INJECTOR o-ring |
Ok. I Will Have To Change Them. Thanks Guys.
Let us know when you do if you need directions, I have a good abridged version kicking around in an e-mail (if your pulling injectors also) just give me a day or two to find it... There are a bunch around here also.
-Robb |
I Will Need Them. I Do Have One More Question. I Noticed When The Truck Gets Warm It Also Has A Mild Romp When It Idles But Not When Its Warm.
