excursion 2002 v10 problems
Old Apr 7, 2008 | 01:59 AM
tequila1800's Avatar
tequila1800
seal rite behind u joints 4x4 just hanging there on both sides there not riped or cracked is this normal? not the seal from the main shaft those are in tackt i pushed them in with my hand but pop rite back out they seem to serve no purpose or do they need to be pressed thank you for your help another question i get chater noise from under the the truck like exaust i took off covers from exaust checked catalic converter nothing. steel does it! not all the time. any body with same problem
Old Apr 7, 2008 | 08:55 AM
i eat hybrids's Avatar
i eat hybrids
Does it only do this when the truck is cold? Like a tickin noise? If so, then u need new exhaust manifolds! Ur missin studs. Get under ur truck and look at the studs on the exhaust manifolds. If u missin some, then this is ur problem. I am missin 2 studs on my left bank. It only ticks when it is cold.
Old Apr 7, 2008 | 10:08 PM
tequila1800
will check thanks
Old Apr 7, 2008 | 11:06 PM
i eat hybrids
Np, let us kno how it goes.
Old Apr 8, 2008 | 09:20 PM
tequila1800
check it out there tight just seems like it could be coming from exaust but noise also seems like it could be coming from trans or something but the noide comes and goes maybe ill wait untill it gets worse or goes away. but do you have any idea why the the seals on both sides are just hanging there nothing is leaking or causing any noise but just there rite by uneverseal joints? almost seems to serve no purpose please respond if you have any idea
pinehillian
Jan 9, 2017 03:02 PM
Bigpipes 35
All Things Towing
22
Oct 3, 2016 09:47 AM
Viperfoxbat
Jul 8, 2016 12:40 PM
Lilbrowntruck
37
Jun 12, 2016 11:47 PM
Boodrow379
20
Mar 21, 2013 09:47 AM
