So I got my new firestone ride rite air bags installed with the firestone compressor. The problem is now the truck is pretty bouncy when empty no matter what pressure I run in the bags. I am starting to wonder if the shocks cant handle the extra bounce from having the air bags, Did anyone else notice this problem and if so what was the fix..
I have a manual one that I built myself. I used a air compressor block with 6 ports. I have the gauge the line out to the bags and the pop off valve on that block. I also installed a fill line on the back bumper to fill the bags if I need to and also to hook a air hose to if I need air for anything else. I have a switch under the hood to inflate and I use the pop off to deflate all while watching the pressure gauge. It isn't as sweet as having the in cab system but it was a lot cheaper and works really well for me.
I never had a problem with my Air Lift 5000 bags, ran them at the lowest recommended 5 psi when empty and never above 45 psi when towing the 5th wheel. Shouldn't be "bouncy" at all. What kind of shocks do you have and how old are they?
I too wonder if the current shocks are the problem. No issues here after last two trucks with air bags. No bounce.
I have no bounce with my Firestone's unless I forget to drop the air pressure to 10 pounds or less unloaded. I do have good shocks as the less then great Ford's were 'all in' long ago and replaced a few weeks before the bags were installed.
My now gone '06 had the Ford FX4 Ranchos. At 38K miles decided they were shot. Took them off and stood them in a garage corner waiting their last trip --- to the dump. 3 of the four collapsed to the minimum height. On went a set of Bilsteins. The current truck has KYB and to my way of thinking, just as good at a bunch less dollars then the Bilsteins.
