stripped oil drain plug???
Old Apr 6, 2008 | 10:44 PM
berg87's Avatar
berg87
I'm part way into the famous upper/lower intake manifold gasket and front cover gasket replacement job, and its getting worse every day.
day one; piece of cake, day two; five broken bolts- two holding the A/C comp bracket, two holding A/C comp to the bracket and one water pump bolt. day three; after fighting wth the broken bolts, only two remain.
I went to reinstall the Oil drain plug and it seemed "stripped". After closer inspection it appears a Heli-Coil has been installed but, it is messed up. I pulled the coil insert out with pliers and the drain plug hole is smooth. I thought it would be "tapped" / "threaded" to recieve the Heli-coil insert.
Anyone have an answer for this. If i do have to tap the oil pan will it need removed?
Thanks in advance. And like many have said this site does indeed
Old Apr 7, 2008 | 08:34 AM
BrianA's Avatar
BrianA
I don't know for sure if you'd have to remove the oil pan to tap new threads. Arguably you should to minimize the risk of metal pieces getting into the pan and possibly making their way through the system in the oil.
If all else fails, I guess you could somehow block that hole off permanently and make a new one.
Or, get a used pan from a junk yard.
Best of luck. Hope it goes well.
Old Apr 7, 2008 | 04:33 PM
BlueOvalFitter's Avatar
BlueOvalFitter
Thumbs up
Just use grease on the tap.Afterwards,buy some very cheap oil and and let it just drain straight thru,flushing out any metal shavings debris.
Old Apr 7, 2008 | 05:25 PM
berg87's Avatar
berg87
thanks for the help. I was just reading about removing the oil pan and it would be difficult for me since i do not have a hoist.
Grease and flush with cheap oil, got it.
I plan to do 3 short (less than 500 miles) oil and filter changes once everything is back together. And use Sea Foam during this time to clean the heads, man they look bad.
I had a machine shop "hot tank" the upper and lower intake manifolds- huge improvement.
I took pics but i'm not permitted to post them, don't know how to resolve that???
Old Apr 10, 2008 | 07:58 PM
F4L956's Avatar
F4L956
what do you mean by "hot tank" & by "huge improvement?
Old Apr 11, 2008 | 12:46 AM
berg87's Avatar
berg87
F4L956- hot tank- to be exact i'm not certain, the guy at the machine shop referred to the process as such. I assume it is a containter/tank of hot cleaning solution. Where parts can be submerged for several hours until clean or at least "cleaner"
My intake parts had a lot (in my opinion) of carbon build up inside the intake runners. after the "hot tank" both upper and lower are very clean, almost as good as new.
hope this helps answer your question. and BTW cost $30 for both parts
Old Apr 11, 2008 | 08:42 AM
F4L956's Avatar
F4L956
"BERG87" Thanks for the feedback well i might need to do the same some day! THANKS AGAIN!
Old Apr 20, 2008 | 08:50 AM
Bear 1's Avatar
Bear 1
I also am having trouble with stripped drain plug.The last time I had my oil changed,they told me it probably wouln not go back in next time.Can it be tapped out?
97 Tbird 3.8
Thanks.
Old Apr 21, 2008 | 04:29 PM
monckywrench's Avatar
monckywrench
I get (two) expandable plugs like this (bring your drain plug for a size match, the reference photo isn't for a Ford) and use one while leaving the other in the glovebox. After plug number one shows wear after a few oil changes, you'll have the second handy. Beats the hassle of swapping the oil pan. Motormite also makes a universal plug.
http://faq.f650.com/FAQs/Photos/Engi...umpPluggim.jpg
Old Apr 21, 2008 | 05:27 PM
berg87's Avatar
berg87
Monckywrench Hey thanks, I never knew a rubber expandable drain was available. I like this option best.
thanks again
as usually FTE comes to the rescue.
Old Apr 21, 2008 | 07:23 PM
monckywrench
"as usually FTE comes to the rescue."
FTE rescued ME enough, happy to help!
Old Apr 22, 2008 | 08:22 AM
BrianA's Avatar
BrianA
Kudos to you guys for helping.
FTE has been a big help to me over the last 8+ years.
A great group of guys and a great deal of knowledge.
Thanks again!
Old Apr 30, 2008 | 03:40 AM
bokker's Avatar
bokker
hi, what is more simple that a expanding rubber bung, well done for finding that. i have never seen one of thoughs before. great get out of jail free device. bokker.
Old Apr 30, 2008 | 04:06 AM
Bear 1's Avatar
Bear 1
Thanks for all the help.I will certanly remember this the next time.
But I already bit the bullet and had the pan replaced.
Old Apr 30, 2008 | 01:50 PM
monckywrench
"hi, what is more simple that a expanding rubber bung, well done for finding that. i have never seen one of thoughs before. great get out of jail free device. bokker."
Note that they come in MANY sizes, and are often referred to as pipe plugs or plumbers (very good for that too!) plugs. They will replace bad core/"freeze" plugs, which is nice when you can't get a straight shot to pound a new one in. Industrial supply houses carry them.
lhud
Jul 12, 2024 02:06 PM
rbrad6937
Modular V10 (6.8l)
Jan 16, 2015 10:45 AM
Huntersbo
21
Jan 4, 2013 10:27 PM
Smellii
Nov 27, 2012 01:21 PM
Argess
Jul 28, 2011 05:00 PM
