heli-coil or something else for stripped threads on carb fuel inlet?
No problem...If ya got a question, check out the Tech Thread Hyperlink Compilation sticky in the 73-79 Dentside forum. I assembled "the best of the best" tech threads/posts so it can be found in one place.... heck, I suggest ya head over there to familiarize yourself on what it covers... it's a gold mine.
Loot at what I found. It's a self tapping 1" carb inlet fitting. Gonna give it a shot. Will post my results.
Dorman Help! 55140 - FUEL INLET FITTING | O'Reilly Auto Parts
You can't get any metal chips inside the float bowl so you are going to have to pull the carb apart to drill and tap. So you need a carb kit. Plus the repair part fpr the thread plus the carb cleaning fluid for the rebuild.
If you start adding up these costs and factor in the risk that the job might go bad, should you not consider buying a rebuilt carb and getting it over with?
arkredneck
11-27-2010 08:18 AM
Supercab
10-14-2001 04:41 PM
