4x2 to 4x4
Old Apr 6, 2008 | 08:01 PM
F700 Pickup_man's Avatar
F700 Pickup_man
4x2 to 4x4
I now this is probably a hot topic somewhere I just couldnlt seem to find it.
I want to convert My 1997 f350, 7.3 liter, crew 4x2 into a 4x4, I know I will be told by a new one,
do me a favor, please. I am not asking for new car advice, so please don't suggest I just purchase one.
can I swap out parts from a same year 4x4 donor, front axle drive shafts, transfer case, etc..and make this possible?
I DO appreciat "VALID" input.
Old Apr 6, 2008 | 08:08 PM
Fullcrew7.3's Avatar
Fullcrew7.3
Yup, you can. So far I've only got the transfer case in and driveshaft shortened. Took from a SC and put in a CC. If the body is the same the parts are the same. Just transfer them all over. Have fun!
Old Apr 6, 2008 | 08:10 PM
F700 Pickup_man
THANNK YOUUUU made my heart skip a beat
next question I guess I should have asked, is there a specific list of items I need to hijack, err I mean transplant from a donor, aside from what I listed previously. sorry to ask, I will have it done so I don't snafu the changeover, but I want to have everything ready.
thanks again
Old Apr 6, 2008 | 08:19 PM
tjbeggs's Avatar
tjbeggs
Here is a list
4wd tranny (or 4wd output shaft and t-case adapter), t-case and shift (with boot and plastic trim), wiring harness for 4wd if you want the light to work, driveshafts, front axle (hub to hub), leaf springs, leaf spring brackets, trac bar and frame bracket, sway bar, links and frame brackets for front axles (rear too if you want), 4 inch blocks for the rear axle to level the truck.
Probably a few things I have forgotten as well. You will be looking at probably $2000 in parts.
Old Apr 6, 2008 | 08:36 PM
superduty4x4's Avatar
superduty4x4
You are looking at $2000 for the D60 front end alone! Transfer case, adapter, trans output shaft all the other stuff I'll bet your looking at no less than a $3K job, plus your time.
Old Apr 6, 2008 | 08:47 PM
tjbeggs's Avatar
tjbeggs
I am in process of selling a D60 and sterling 10.25 for $1100 plus freight. Watched ebay for a while and you can get them for way less than $2K
Old Apr 6, 2008 | 10:28 PM
F700 Pickup_man
My rear axle is 3:55 ratio.
I suppose the front end would match? were I to find an exact year? donor?
or would I need to swap out the rear axle of the donor too?
I don't believe that spending around 3k would be so bad its just I want to make sure I grab the right stuff ya know?
I have a source for the parts, as far as transfer case do I want it with power take off or without? and I know there are two numbered sets but both come with and without, so how do I know?
sorry for all of the questions I am just lost
Old Apr 7, 2008 | 01:51 AM
Fullcrew7.3
Find an apropriate donor (blown engine makes it a cheaper option) and take what you need to form it. If you have the space, get the whole truck. That way you know you have everything you need. I've got 3.55's as well, and the donor truck I'm hoping to pick up locally has 4.10's. I'd really like to stick with the 3.55's though. My truck's a '96 and the donor is a '93.
Old Apr 7, 2008 | 07:47 AM
F700 Pickup_man
cool, how far back in year models can I go?
by the way, you guys all answered me before the four 4wd shops I called last wednesday. thanks you guys here rock.
Old Apr 7, 2008 | 08:34 AM
superduty4x4
Why can't I ever find smokin' deals like that on stuff I need?
F700 Pickup_man- your best bet is to find an axle from a 92-97 truck, but the axle hasn't changed since the early 80's from what I remember. There are also 70's vintage D60 front axles but they are a kingpin axle instead of ball joints and a little harder to shoehorn into the newer rigs.
Old Apr 7, 2008 | 08:43 AM
farmer ford's Avatar
farmer ford
could a guy put in different ring gears and change the now 4.10's to 3.55's?
Old Apr 7, 2008 | 09:23 AM
IceboxFX's Avatar
IceboxFX
you sure could.
Old Apr 7, 2008 | 11:38 AM
tjbeggs's Avatar
tjbeggs
Like it was said 94-97 will be the best option (larger brakes) for your donor vehicle. But you could go back farther than that
Old Apr 7, 2008 | 12:43 PM
250turbo's Avatar
250turbo
f700,check out MARK62's gallery.
kurt
Old Apr 7, 2008 | 01:41 PM
secondarychaos's Avatar
secondarychaos
Sounds like a cool project!
Mine is already 4x4, and i want to see the writeup
Good luck!
