problem with 292 revving
Old Apr 6, 2008 | 03:23 PM
Hurk's Avatar
Hurk
I finally got my truck started a couple of month ago. The timing was a problem. Now whenever i try to rev the truck it just bogs down. I check the carb and saw it was getting good streams of fuel. I think the problem is with the timing since the distributor has to be turned all the way counter-clockwise just to be able to start. I thought that the distributor shouldn't have to be turned that much 1 way or the other just to start. Could the timing be my problem or is there somthing more too it? Thank for reading.
Old Apr 6, 2008 | 11:16 PM
46yblock's Avatar
46yblock
What do you have the initial advance set at?
Old Apr 8, 2008 | 06:45 AM
312's Avatar
312
your going to have to move the dist,
Old Apr 8, 2008 | 03:04 PM
Sam_Fear's Avatar
Sam_Fear
If the plug wires were ordered to a 302, odds are the PO had the distributor out also. Like 312 says, you'll need to pull it out, rotate it, and put it back in. Time it with a light to spec (4 degrees BTDC I would guess) and see what that gets you. Someone could have put a new timing chain on wrong or the damper could have moved, so it could still be off.
Old May 22, 2008 | 03:37 PM
newbyyhead03's Avatar
newbyyhead03
cud be off a tooth on dist.
Old May 22, 2008 | 03:38 PM
newbyyhead03
also chk fuel pressure cud have clogged filter or sumting. my filter got clogged and wud idle great but wud bogg way down when i put my foot in it.
Old May 23, 2008 | 05:45 AM
Hurk's Avatar
Hurk
Alright I will try that. I was thinking either one but it seems my problem is similar to what you said
Old May 23, 2008 | 03:52 PM
Y-Blockhead's Avatar
Y-Blockhead
Whoa, you could actually read and understand what that guy wrote?? My hat is off to you...
Y-Blockhead
Gigemags05
Feb 19, 2015 09:20 PM
jason08
23
Dec 27, 2008 10:22 AM
gus 166
Dec 14, 2008 08:51 AM
ErrorS
22
Nov 11, 2007 07:16 PM
'73 250
Feb 16, 2005 11:28 PM
