92 f150 starting/running problem
Old Nov 30, 2008 | 07:52 AM
gus 166's Avatar
gus 166
i have a 92 f150 4.9. one day truck would not start. sounded like it was out of time.if i turn distributor clock wise all the way it will start.it runs barely, i let it run then slowly turn distributor back to were it was.it will idle all day.if i give it to much gas it dies.feather the gas and it is driveable.shut it off for two seconds wont start.
Old Nov 30, 2008 | 08:48 AM
Redcat Diesel's Avatar
Redcat Diesel
First off I'd hook up a fuel pressure gauge and check the reading. Since it does start the ignition system is working. Low fuel pressure could cause the problem.
Old Dec 14, 2008 | 07:02 AM
gus 166's Avatar
gus 166
fuel pressure ckecked good.i had one code 327 .that is'' egr valve position circuit below minimum voltage.'' i dont think this would effect start up.any more ideas would be appriciated.
Old Dec 14, 2008 | 07:13 AM
deeznuts822's Avatar
deeznuts822
Bad pickup coil?
Old Dec 14, 2008 | 07:26 AM
Redcat Diesel
An EGR valve stuck open would make it hard to start.
Old Dec 14, 2008 | 08:51 AM
Opossum's Avatar
Opossum
Sounds like it is out of time, have you put a timing light on it?
mdwirth
21
Feb 1, 2017 01:21 AM
Oldanvilyoungsmith
55
Apr 29, 2016 10:02 AM
Dillingerj
Nov 12, 2015 11:00 AM
slickeast
Jan 28, 2011 08:49 AM
myddad
16
Feb 1, 2007 02:49 PM
