Ok Guys.... What should I do
The past couple of days I have been looking at F-350 7.3's and I've found a few that I like. 2001 101,986 miles $19.850 fully loaded, I'm new to the diesel trucks but I tried to check anything the board said check. 02 90,685 miles $20,978 fully loaded same here truck seems to be a good truck. 02 37,576 miles $22,000 cloth interior, I didn't notice where they have been pulling anything with this truck and it also seem to be a good truck. They all seem to shift fine. So with all this being said what should do or do I need to keep looking. I will be using the truck to pull a wedge 3 car trailer.
THANKS IN ADVANCE
THANKS IN ADVANCE
Welcome to FTE. are these three at a FORD dealer? If so ask to have an OASIS report pulled on each one. (or if you get the VINs you can go up to the 6.0 forum and those guys will pull one for you. )
but if it was me i would go with the 02 htat has 37K miles on it.(if you like the color and options.)
Thanks
No Oasis and Carfax are not the same.
The Oasis report shows all work done to that truck at any dealership. Warranty work, etc. It is a good idea to get this done before buying any truck, lots of hidden information can be uncovered.
If you go to the 6.0 forum, like stated, there is a sticky at the top abotu Oasis reports and you can post your VIN and email addy and someone tehre will take care of you. I have even had them back in as quick as an hour before.
Ok
Standard Claims List For Model Year 2001
VIN VEH LINE MKT DERIV BODY CAB VER SERIES DRIVE TYPE PLT CD TRS CD ENG CD PROD DATE WARR DATE SELLING DEALER SELL CNT TIS WCC CPSC_6 PREF BASE SUFF CCC CD DIST(Miles)
1FTWW32F71ED21632 T/F7 F T/BC T/CD T/B A1 T/DQ T/DS 04-MAY-2001 25-MAY-2001 124514 USA 1 5G05 040001 * FRONT * H25 W6 644
AWS Claim Key: 2006062 Trx Code: 1 Labor Hrs: 1.9
Dlr Cd-Sub Cd: 00284 - * Name: WALT'S LIVE OAK F-M INC Ph: 386-3621112 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:08-JUN-2001 Doc #:064144A
Cust Comments: CHECK TRUCK PULLS TO RIGHT WHEN DRIVING***WARRANTY***
Tech Comments: TEST DRIVE RAN OASIS CEHCK ABS REPLACED CAMBER CASTER BUSHING RESET TOE TO SPECS TEST DRIVE OK
1FTWW32F71ED21632 T/F7 F T/BC T/CD T/B A1 T/DQ T/DS 04-MAY-2001 25-MAY-2001 124514 USA 4 6E01 011001 1C3Z 2560136 BAA B54 33 6199
AWS Claim Key: 3448630 Trx Code: 1 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 00284 - * Name: WALT'S LIVE OAK F-M INC Ph: 386-3621112 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:27-AUG-2001 Doc #:066242A
Cust Comments: CHECK CENTER CONSOLE LEATHER IS LOOSE***WARRANTY***
Tech Comments: REMOVED CONSOLE COVERS TO R&R CENTER CONSOLE PER FABRIC TREAD TORN LOOSE AND REINSTALL
1FTWW32F71ED21632 T/F7 F T/BC T/CD T/B A1 T/DQ T/DS 04-MAY-2001 25-MAY-2001 124514 USA 10 6D05 011000 F81Z 25672A28 DDD B95 01 13545
AWS Claim Key: 7360705 Trx Code: E84 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 00284 - * Name: WALT'S LIVE OAK F-M INC Ph: 386-3621112 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:02-MAR-2002 Doc #:071079A
Cust Comments: C S PEICE ON PASSENGER SIDE OF ARM REST BROKE **ADVISE**
Tech Comments: REPLACE ARM REST
1FTWW32F71ED21632 T/F7 F T/BC T/CD T/B A1 T/DQ T/DS 04-MAY-2001 25-MAY-2001 124514 USA 32 5G01 040101 * 5310 * N59 82 34539
AWS Claim Key: 16956984 Trx Code: E84 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 00284 - * Name: WALT'S LIVE OAK F-M INC Ph: 386-3621112 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:30-DEC-2003 Doc #:089035A
Cust Comments: CUST STATES NOISE IN L F SUSP,WHEN TOWING ANYTHING
Tech Comments: CUSTOMER STATES NOISE IN L F SUSPENSION, WHEN TOWING ANYTHING, UNABLE TO DUPLICATE PROBLEM AT THIS TIME.
1FTWW32F71ED21632 T/F7 F T/BC T/CD T/B A1 T/DQ T/DS 04-MAY-2001 25-MAY-2001 124514 USA 32 5O01 110200 * 3504 * L68 82 34539
AWS Claim Key: 16956985 Trx Code: E84 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 00284 - * Name: WALT'S LIVE OAK F-M INC Ph: 386-3621112 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:30-DEC-2003 Doc #:089035B
Cust Comments: CUST STATES FLUID LEAK UNDER F END AT TIMES
Tech Comments: CUSTOMER STATES FLUID LEAK UNDER F END AT TIMES, COULD NOT DUPLICATE PROBLEM AT THIS TIME
1FTWW32F71ED21632 T/F7 F T/BC T/CD T/B A1 T/DQ T/DS 04-MAY-2001 25-MAY-2001 124514 USA 32 5V01 060101 * 1104 * N50 33 34836
AWS Claim Key: 17039187 Trx Code: E84 Labor Hrs: 1
Dlr Cd-Sub Cd: 00284 - * Name: WALT'S LIVE OAK F-M INC Ph: 386-3621112 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:06-JAN-2004 Doc #:089199A
Cust Comments: FRONT END NOISE
Tech Comments: ROAD TEST HUMMING GROANING NOISE LEFT FRONT, INSPECTED FRONT WHEEL BEARINGS LOOSE., REMOVED BOTH FRONT WHEELS AND CALIPERS AND ROTORS, WHEEL BEARING HAVE VERY LITTLE GREASE, REPACKED BOTH FRONT WHEEL BEARING WITH GREASE, REASSEMBLE AND SET WHEEL BEARING PRELOADED, ROAD TEST
1FTWW32F71ED21632 T/F7 F T/BC T/CD T/B A1 T/DQ T/DS 04-MAY-2001 25-MAY-2001 124514 USA 32 * * * * * * * 34836
AWS Claim Key: 17039188 Trx Code: 01S21 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 00284 - * Name: WALT'S LIVE OAK F-M INC Ph: 386-3621112 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:06-JAN-2004 Doc #:089199C
Cust Comments: CAMPAIGN 01S21
Tech Comments: PERFORM RECALL
1FTWW32F71ED21632 T/F7 F T/BC T/CD T/B A1 T/DQ T/DS 04-MAY-2001 25-MAY-2001 124514 USA 32 5A12 050201 EOTZ 1244 A N51 14 34836
AWS Claim Key: 17039189 Trx Code: E84 Labor Hrs: 3.3
Dlr Cd-Sub Cd: 00284 - * Name: WALT'S LIVE OAK F-M INC Ph: 386-3621112 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:06-JAN-2004 Doc #:089199D
Cust Comments: NOISE IN REAR END WHILE DRIVING
Tech Comments: NVH DIAG, INSTALL CHASSIS EARS AND ROAD TEST LEFT REAR WHINES LOADED, TEAR DOWN REAR DIFF., REMOVERING AND PINION ASSY, FOUND LEFT REAR CARRIER BEARING DAMAGED AND RACE CRACKED REPLACED LEFT CARRIERBEARING AND RACE INSPECTED ALL OTHERS OK CLEAN HOUSING AND REASSEMBLED FILLED FLUID AND ROAD TEST OK
1FTWW32F71ED21632 T/F7 F T/BC T/CD T/B A1 T/DQ T/DS 04-MAY-2001 25-MAY-2001 124514 USA 50 2B01 0300XX F7TZ 12K073 A D50 42 55197
AWS Claim Key: 20097445 Trx Code: E72 Labor Hrs: 0.9
Dlr Cd-Sub Cd: 00284 - * Name: WALT'S LIVE OAK F-M INC Ph: 386-3621112 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:01-JUL-2005 Doc #:104577A
Cust Comments: VEHICLE CUTS OFF WHILE DRIVING AND WILL CUT OFF AT RED LIGHTS, CHECK ENGINE LIGHT HAS BEEN ON BEFORE AND GONE OUT
Tech Comments: PERFORM DIESEL DIAG., INSTALL CMP TESTOR, CAM SENSOR OPEN INTERMITTENTLY, REPLACE CAM SENSOR
1FTWW32F71ED21632 T/F7 F T/BC T/CD T/B A1 T/DQ T/DS 04-MAY-2001 25-MAY-2001 124514 USA 61 2H01 030008 2C3Z 9P466 AB L65 01 72918
AWS Claim Key: 21170690 Trx Code: E72 Labor Hrs: 6
Dlr Cd-Sub Cd: 00284 - * Name: WALT'S LIVE OAK F-M INC Ph: 386-3621112 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:22-MAY-2006 Doc #:114218A
Cust Comments: LEAK SOMEWHERE NEAR OIL PAN, IF IT IS TRANSMISSION SEAL PERFORM SERVICE WHILE WE HAVE THE PAN OFF
Tech Comments: DIAG OIL LEAK FOUND TURBO PEDISTOL LEAKING OIL WHILE REMOVING TURBO TO FOUND Y PIPE GASKETS LEAKING BROKE BOLTS REMOVING Y PIPE REPLACED Y PIPE GASKETREASSEMBLED AND ROAD TEST RECHECKED NO LEAKS
Standard Claims List For Model Year 2002
1FTWW32F12EB64732 T/F7 F T/BC T/CD T/B A1 T/D8 T/DS 04-DEC-2001 20-APR-2002 121556 USA 9 3A08 070105 XL3Z 7902 DARM P59 42 10374
AWS Claim Key: 4079384 Trx Code: 2 Labor Hrs: 4.7
Dlr Cd-Sub Cd: 03031 - * Name: PIONEER FORD-MERCURY Ph: 770-5372373 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:07-JAN-2003 Doc #:03474401
Cust Comments: CUST STATES TRANS SLIPPS UNDER LOAD CC P09
Tech Comments: DIAG ROADTEST PINPOINT TEST TRANS CONVERTER LOCK UP R AND R TRANS REPLACED TOQURECOVERTER ROADTESTED CC 42
1FTWW32F12EB64732 T/F7 F T/BC T/CD T/B A1 T/D8 T/DS 04-DEC-2001 20-APR-2002 121556 USA 20 5T01 * * * * * * 14471
AWS Claim Key: 8424555 Trx Code: 03B03 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 03031 - * Name: PIONEER FORD-MERCURY Ph: 770-5372373 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:08-DEC-2003 Doc #:03956402
Cust Comments: CUST REQ PERFORM ADJ PEDAL CAMPAIGN 03B03
Tech Comments: REPLACE SENSOR ASSEMBLY AS PER CAMPAIGN 03B03
1FTWW32F12EB64732 T/F7 F T/BC T/CD T/B A1 T/D8 T/DS 04-DEC-2001 20-APR-2002 121556 USA 20 5A06 050201 3C3Z 4880 AA L86 42 14471
AWS Claim Key: 8424556 Trx Code: E84 Labor Hrs: 3.4
Dlr Cd-Sub Cd: 03031 - * Name: PIONEER FORD-MERCURY Ph: 770-5372373 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:08-DEC-2003 Doc #:03956403
Cust Comments: CUST STATES VEH SHUDDERS WHEN TURNING IN REVERSE
Tech Comments: CHECK CONCERN R AND I DIFF CARRIER AND REPLACE CLUTCHES AS PER TSB 0
r10kidds
08-20-2009 10:55 PM
