Timbren SES Kit
Old Apr 4, 2008 | 10:26 PM
karboman's Avatar
karboman
Timbren SES Kit
Has anyone used Timbren SES kits before? If so, any feedback? I am thinking about getting a set for my 97' F150 to help out with stability and sag for when I am towing (around 5000 lbs - travel trailer). I still will also use a weight distribution hitch set up as well. It does not seem to take much gear in the back of the truck to settle down the rear end a few inches.
Old Apr 5, 2008 | 01:11 PM
Tony G's Avatar
Tony G
Have em on my F350 and they work great. Can handle an extra ton in the bed. The weight distributing hitch alone might be good for the travel trailer though. They work very well. BUT if a small travel trailer sags your backend and you put a distribution hitch on it, you might end up taking weight off of your rear axle with the WD hitch.
The timbrens might solve both problems of weight in the bed and extra stability needed when towing. Then if the TT makes the front end light, add the WD hitch.
hunter1022
Apr 13, 2016 09:16 PM
rled
6.7L Power Stroke Diesel
20
Apr 12, 2016 05:43 PM
mikereidjr
All Things Towing
May 12, 2015 04:04 PM
SuperDoodie
27
May 22, 2009 02:57 PM
Champ198
Oct 18, 2007 07:05 AM
