starts great...sometimes...
Old Apr 4, 2008 | 04:38 PM
lydia's Avatar
lydia
Hi, I'm a new poster and would appreciate your advice. My 97 V6 3.0 (150,000 miles) runs great and starts right up, most of the time. For about the last 6 or 8 months, she occassionally won't start if I try to restart within 5 minutes or so of shutting off the engine. Turns over, just won't start. It's beginning to happen more often, say half the time I turn the engine off briefly before restarting, like when I stop for gas, but if I wait for 10 minutes, she'll start easily and always runs great. Length of time I've been driving doesn't seem to matter and neither does outside temp. The engine light is off. Battery is only a year and a half old.
Any thoughts?
many thanks, Lydia
Old Apr 4, 2008 | 08:24 PM
michigan66's Avatar
michigan66
Welcome to FTE. This is the place to get lots of good help.
When did you last have the truck tuned up - new plugs and wires? What does your temp guage indicate - is the engine running hot? If so, flushing the cooling system and replacing the thermostat may be the cure.
Old Apr 6, 2008 | 11:50 AM
lydia's Avatar
lydia
Thanks, michigan66:
Tuned up around 100,000 miles, and the temp gauge is as it should be, not running hot. Although I've been intending to change coolant for routine maintenance before summer kicks in....
A friend had a similar problem with a Mercury, and it turned out to be the fuel pump. In my own experience, fuel pumps either work or they don't, instead of working intermittently, so I was curious if any other Ranger owners had encountered a similar fuel pump problem. Don't want to drop the tank unless I have to!
Old Apr 9, 2008 | 08:17 PM
michigan66's Avatar
michigan66
Where's all the help? Does anyone else have any ideas or suggestions for Lydia?
Old Apr 9, 2008 | 08:43 PM
crazypaw's Avatar
crazypaw
Wink
Welcome to FTE lydia,
When in doubt pull the codes for possible resolutions.
And sometimes it takes time to gather answers when others read your thread.
Old Apr 10, 2008 | 09:15 AM
sfcwoodret's Avatar
sfcwoodret
Check the fuel pump because it's starting to wear out.
Old Apr 10, 2008 | 10:16 AM
fordboy_52's Avatar
fordboy_52
fuel pump or coil box (cant remember the name)
Old Apr 10, 2008 | 10:26 AM
tomw's Avatar
tomw
Listen for the pump activating for about 3-5 seconds when you turn the ignition key to "ON", not start. If the pump does not make its whining noise, there are several things to check. If it does make the noise, then the likely problem is in the ignition system. I had a distributor pickup coil in an Escort that would do the same thing you describe. Go to the store, buy groceries, get in to go home. Watch ice-cream melt. The pickup has a bazillion turns of hair-thin wire, and it would break continuity when it got to a specific temperature. Wait a bit, and it worked. Dickens to find.
Your truck has a different system, but it could be similar. Pull the codes, and the next time it fails to fire, check for spark. Sounds easy, but it's not that hard.
tom
Old Apr 10, 2008 | 10:39 AM
fordboy_52's Avatar
fordboy_52
yea, there is no pickup coil or ignition module. I had the same symptoms when my coil pack went out (and they arnt cheap.......)
Old Apr 10, 2008 | 11:21 AM
wtroger's Avatar
wtroger
First you have to determine whether it is fuel or fire. As was stated can you here the pump run when you turn the the key to run if not maybe a fuel pump. If you can here pump then you have to check for fire. How long a trip does it take for this to happen? If you can reproduce it at any time it will be easier to fix. One quck trick to try on the fuel pump is smack the bottom center of the gas tank with a rubber mallet and see if it starts right up. I have seen that work more than once. If it works then the pump is going south.
Old Apr 10, 2008 | 05:10 PM
golddirt's Avatar
golddirt
check the 10 dollar fuel pump relay's under the hood. when you turn the key on you should hear 2 clicks, if not thump the relays and i bet it will start.
Old Apr 10, 2008 | 10:04 PM
tomw's Avatar
tomw
A *good* mechanic, if you can find one, can do a current draw test on your fuel pump(s) to know if they are on their last legs. As they age, the current draw increases, from what I have heard. When it gets to a certain point, it indicates that the pump is very close and standing on a banana peel...
tom
Old Apr 10, 2008 | 11:34 PM
fordboy_52's Avatar
fordboy_52
thats not always true. my boss showed that too me this summer. the easiest way to check out a fuel pump is just doing a rail preasure test.
Matt
Bruce678
Jan 4, 2014 09:28 PM
hall442
16
Aug 1, 2012 09:57 AM
lydia
Jul 19, 2010 08:51 PM
Boss50
Mar 21, 2010 03:40 PM
lydia
Mar 4, 2010 08:24 AM
