Coolant Filters
Old Apr 4, 2008 | 08:33 AM
jmaskew's Avatar
jmaskew
Coolant Filters
Does anyone know what the equivalent filter is for the Baldwin 5134 at Autozone, Checker, Pepboys, Walmart, etc? I have been looking online this morning and have had no luck. Thank you.
Old Apr 4, 2008 | 08:59 AM
PowerStrokeHD's Avatar
PowerStrokeHD
It is unlikely that you will find coolant filters at your basic local auto parts store. You would have better luck at a medium/heavy truck dealers parts counter or a medium/heavy truck parts supply store.
Have you tried Baldwin's dealer locator which can be found on the left side of the homepage to see if there is anyplace close to you?
Baldwin Filters
Other filters that are equivilant to the Baldwin BW5134...
Donaldson - P554685
Fleetguard - WF2077
Luber-Finer - LFW4685
FRAM - PR3383
Old Apr 4, 2008 | 09:02 AM
Kep4's Avatar
Kep4
Jäger
Here's a cross-reference chart for you: Cross Reference | Purolator Facet, Inc. : Filtration products for industry, aviation, hydraulics
And for Wix: WIX Filters : Filter Look-Up
Well, the new format does some different things with links! Click on 'WIX' for the Napa PN, the other two take you different places than intended.
Old Apr 4, 2008 | 09:18 AM
jmaskew's Avatar
jmaskew
Thank you! There are a couple of Baldwin dealers in Las Vegas I can check out. I would prefer to purchase locally to avoid the shipping charges online. Thanks again.
Old Apr 4, 2008 | 09:48 AM
jmaskew's Avatar
jmaskew
Carquest in Las Vegas carries the "WIX 89070" filter for $11.xx. Will be picking one up after work. Thanks again guy's for the info.
Old Apr 4, 2008 | 05:39 PM
slowmans's Avatar
slowmans
I have some extra baldwin filters I would like to get rid of, but they are the shorter version of the 5134 they are the 5089, pm me if your interested!
Old Apr 4, 2008 | 07:31 PM
UGA33's Avatar
UGA33
Im using a Hastings filter. Is this ok?
Old Apr 4, 2008 | 07:37 PM
bismic's Avatar
bismic
I have heard some good things about Hastings in the past, but you probably need to make sure it is a filter made for coolant or water based applications. what model number?
Old Apr 4, 2008 | 07:38 PM
bismic's Avatar
bismic
Slowmans - why are you getting rid of the 5089's??? I just decided to go to these.
Old Apr 4, 2008 | 07:45 PM
jmaskew's Avatar
jmaskew
I just changed out my filter; I poured the coolant into a funnel lined with a coffee filter and WOW it was a dark brown muddy liquid. I ended up having to pour the coolant out of the funnel because it was plugged up with all the dirt/sand. I think I went too long before changing it the first time (about 2,000 miles). Question - How the heck do you guy's cut open the filter housing? I can't wait to see what that looks like inside.
Old Apr 4, 2008 | 08:23 PM
slowmans's Avatar
slowmans
I bought a case and dont need them all...
Old Apr 4, 2008 | 08:47 PM
bismic's Avatar
bismic
Hey JMASKEW - are you using filters with supplemental coolant additives (SCA's)? If so, you shouldn't. The folks at Dieselsite told me that what you should get out is particles. If you are getting "mud" then they said it indicates that you are probably dropping some of the additives out of solution. Some filters come w/ extra additives in them - these are the ones to avoid.
Edit:
Specifically ask for "non-charged" filters. These are the ones without the timed-release tablets.
Old Apr 4, 2008 | 10:07 PM
UGA33's Avatar
UGA33
I told the guy behind the counter at APC (Auto Parts Company) to cross reference the Baldwin filter that i got with the kit and when he handed me the filter i asked him to make sure it was the non-charged one which it was. Its raining cats and dogs outside, so i aint gonna attempt to get the part number tonight
Old Apr 4, 2008 | 10:33 PM
jmaskew's Avatar
jmaskew
Edit:
The filter I just removed was the Baldwin BW5134 that came with the kit. It is a non-charged filter. The one I purchased today is also non charged, I think my engine is full of sand. Thanks for the post.
The "crud" is actually particles... a lot of them. I'll post pictures this weekend when I open the filter (if I can get it open).
Old Apr 4, 2008 | 10:42 PM
UGA33's Avatar
UGA33
grinder with a cutting disk worked wonders when i opened my first one up
