Drivetrain Klank
I have had the following done and still the same Klank
New Rear Drive shaft
New Ujoints (2times)
Slip Yolk serviced.
New Gears
New Carrier Bearings
New Seals
I was told by one of te driveline people that it could be the transfer case chain? Has anyone heard of that being an issue The X has 97K miles
Thanks
</TD></TR></TBODY></TABLE>
></O
>1. backlashing in the gears<O
></O
>2. transfer case chain is loose<O
></O
>3. carrier bearing is bad<O
></O
>4. seals<O
></O
>5. u-joints<O
></O
>6. driveshaft length<O
></O
>7. drivetrain angle where it connects to the rear diff<O
></O
>8. the limited slip in the rear diff<O
></O
><O
></O
>So, I've had seals replaced, backlashing checked, transfer chain checked, carrier bearing replaced, u joints inspected (they were fine), friction modifier added to rear diff. I even found a link on this site that did a walkthrough of "superduty driveline clunk." It described that all superduty's have or will have a clunk due to a dry slip yoke. So, I took it in to get that serviced. Nothing worked. It has been infuriating. I finally got pissed off and decided to try lubing the slip yoke myself as per the instructions. Well, I soon realized that the pictures the guy posted were backwards from the way my driveshaft looked. Upon further investigation, I read that some superduty's had the driveline installed backwards. I don't know if his is backwards or if it is mine, but I stopped following the directions at that point. I took the entire driveshaft off from the front of the truck to the rear diff. I quickly discovered that when I took my truck to have the slip yoke serviced, they never did it. So much for Ford service. I got a big tube of grease and slapped it on the slip yoke, lined everything back up, and bolted it back on. I really didn't think that what I had just done would fix the problem. But, I started my truck up and drove it around and couldn't have been happier! I have clunk free driving now. It has now been two weeks since I have done this, and I haven't had a single clunk. Now, it might be the grease that fixed it, or it might be that I took the driveline off and changed the alignment ever so slightly. Whatever it was, 45 minutes of tinkering and a $5 tube of grease was worth the long shot of fixing such an annoying problem.<O
></O
>__________________
