What engine is this anyway
Old Apr 3, 2008 | 11:24 AM
Phils Ford's Avatar
Phils Ford
Well bought a F-150 on ebay big mistake first thing I had to do replace the trans big chunks of metal in the pan. Now I'm having engine problems I have a 91 F-150 which needs a new distributer called the dealer and the dealer is telling me the E4ZE-12131-AA distributer is a 1984 casting. So now I'm really confused. Can anyone tell me how to know for sure what year motor I have
I'm hoping they just swaped the distributer with the wrong one yet I am going to rebuild from the ground up and want to make sure it gets done right this time. Is there a casting on the block to tell me what motor I have? If so where should I look for it?
Thanks
Phil
Old Apr 3, 2008 | 11:57 AM
Conanski's Avatar
Conanski
First thing you got to do is identify the motor.
Is it an I6 or V8
If V8 is it 5.0 or 5.8?
Carb or EFI?
Once you know this just order a distributor for that motor. The casting number doesn't tell you anything besides the first year it was used, and it could have been used for many years.
Old Apr 3, 2008 | 12:16 PM
Virto's Avatar
Virto
If the motor is correct for the year (and hasn't been messed with) the V8s have either 5.0 or 5.8 EFI on the top of the intake manifold.
The only I6 in this body style of trucks (and back to at least the 71+ models) is the 300ci.
Old Apr 3, 2008 | 01:39 PM
Phils Ford's Avatar
Phils Ford
Thanks Guys
I know it is a V-8 EFI 5.0 is there a way to find out if someone swapped the motor or if it is the original motor for this truck? I am being told the distributer is either cast iron gear or steel gear. No one can tell me for sure.
Thanks
Old Apr 3, 2008 | 01:49 PM
Conanski's Avatar
Conanski
Original motor for that truck or an accurate replacement would have a distributor with a cast iron drive gear.
Old Apr 3, 2008 | 01:59 PM
Phils Ford's Avatar
Phils Ford
Thanks
You are a life saver take care.
Phil
Old Apr 3, 2008 | 03:40 PM
jas88's Avatar
jas88
Just FYI the 240 was the base engine thru 1974. The 300 was optional starting in 1965 and became the standard engine in 1975. The 300 was used thru the 1996 model year.
Old Apr 3, 2008 | 06:57 PM
gweeds's Avatar
gweeds
If you need to know any other specs (within reason) about your new truck, look up a vin decoder, supposing that it wasnt removed or otherwise tampered with...
Old Apr 3, 2008 | 07:14 PM
handsomerob's Avatar
handsomerob
A 302 engine block between 1986-1993 will have a part number of E6SE-DC a 1983-1984 will have a part number E2AE-KA.
If you can find the part number on the block that will difinitively let you know what you have within the ranges.
oldbikedude
Jul 11, 2019 07:57 PM
WILD_PHIL
New Member Introductions
Jul 27, 2016 10:05 PM
Legendary351
Aug 26, 2015 06:00 AM
horsemanraul
Mar 12, 2015 10:00 AM
pro98
15
Jul 27, 2009 02:45 PM
