I folks, My name is Phil & I am in the midst of rust repair salvage. My frame is bad & I'm doing what I can with it & addressing many issues at the same time. I'm doing this as the money comes in and it's turned into a pretty big project for me. I'm gonna post some pics. I hope you all enjoy them.
I had to make a "X" member out of 2" X 3" box tubing & 1/4" plate steel. Also a spare tire lift rack & I'm also adding a piece of 3" channel across the rear of the frame rails. Grade 8 hardware where I can.
I used Corraseal rust converter. Then a couple coates of duplicolor engine enamel (held up to the weather better than any of the other paints I tried). Corraseal worked great.
I'll post more tomorrow. I've done a lot to her. New parking brakes, brake backing plates, hub seals,discs, ceramic pads. New brake lines, hoses, shocks & rear cover. Installed new muffler & tail pipe. sneek peek.
