Gear Ratio?
Old Apr 2, 2008 | 09:31 PM
spence13e's Avatar
spence13e
i would lean to you having 3.55's. my 95 gasser with 3.55 on the stock 235/85R16s ran around 1700 @ 60 and my 04 with 3.73's on the same tire size runs right around 1750 at 60.
Old Apr 2, 2008 | 09:50 PM
scatgo's Avatar
scatgo
Originally Posted by tjbeggs
Never heard of it. Do you have a f-superduty or a straight up F-350?
F-350. Just looked again it is D5!?
Old Apr 4, 2008 | 08:48 AM
tjbeggs's Avatar
tjbeggs
Beats me.....I would guess no matter what you have 4.10's but I can't be sure.
Old Apr 4, 2008 | 08:57 AM
dinikin's Avatar
dinikin
If you buy your truck for empty or very light towing then yes. 3.55 will yeild better MPG.
4.10 with larger tires will kinda make it 3.8 or close to it.
When towing heavy loads 4.10 will get better mpg,
PLus 3.55 gears are only rated towing up to 10,000lb(if not mistken) and 4.1 up to 15,000lb
Originally Posted by Bino2
So just so I can be clear would 3.55 get better mpg than 4.10 and if you have bigger tires can't you get better mpg to a certain extent or in certain situations?
Old Apr 4, 2008 | 10:33 AM
444dieselrod's Avatar
444dieselrod
Check this out a Google shearch lead me right back here.
Ford Axle Code Chart .: Articles
D5 is 4:10LS gear.
Diesel Rod
Old Apr 4, 2008 | 10:35 AM
tjbeggs's Avatar
tjbeggs
Cool makes since. The DRW trucks have a higher rated capacity so they get a different code. Makes sense!
Old Apr 4, 2008 | 11:22 AM
scatgo's Avatar
scatgo
Thanks for the info Dieselrod. Tryed to rep ya but you know how it goes. Got to spread it around. What is up with Limited Slip? Not sure what that means.
Old Apr 4, 2008 | 12:51 PM
444dieselrod
means if your in the mud both wheels will spin not just one, alot better in these trucks I think, both mine are open and ya get stuck on a wet leaf.
Diesel Rod
Old Apr 4, 2008 | 11:23 PM
NWBronco's Avatar
NWBronco
A limited slip, if properly maintained, is marginally better than an open diff. The friction packs in those go pretty quick even with a friction modifier.
Bob
Old Apr 5, 2008 | 10:44 AM
c00nhunterjoe's Avatar
c00nhunterjoe
worse case just pop the rear cover off and read what the ring gear is stamped.......
Old Apr 5, 2008 | 10:45 AM
c00nhunterjoe
meborder
Mar 8, 2014 09:28 AM
Shanemh
Feb 25, 2012 06:56 PM
meporsche
Oct 1, 2010 02:57 PM
Andy's '79
Sep 27, 2007 08:12 PM
biglee
1947 and Older Ford Trucks
Feb 15, 2004 07:24 AM
