Code P1249
Old Apr 1, 2008 | 09:41 PM
jrf250's Avatar
jrf250
Code P1249
Checked for codes on My truck tonight, Found P1249. Waste gate steady state failure. What can be done to fix this and will this make Me have bad fuel millage? Have been getting about 14 mpg lately. Use to get 18. Any help or response will be appreacted.
Thanks
Old Apr 2, 2008 | 01:58 AM
PaysonPSD's Avatar
PaysonPSD
This is what I saw listed as probale cause -GND short, plugged hose/port, wastegate solenoid, wastegate actuator
Wastegate problem could cause loss of boost which can lower MPG.
The wastgate solenoid is mounted on the front of the spider. Check to make sure the connector is tight. The red line from the wastgate actuator runs to it as well as a green line from the intake hose that goes to turbo. Check those lines.
Picture of wastgate solenoid. It may be mounted vertically as well.
I have no idea on how to check for the GND(ground) short. This is all the help I can give unless I think of something else. At least you will get a bump up the list.
Old Apr 2, 2008 | 06:04 AM
jrf250's Avatar
jrf250
Thanks for the info. I will look at that this evening when I get home. Rep points to You.
Old Apr 2, 2008 | 08:26 AM
rbaker6336's Avatar
rbaker6336
I always got the 1249 code anytime the boost got to 25lbs,I get it all the time since I tightend the waistgate rod
Old Apr 2, 2008 | 09:59 AM
Action4478's Avatar
Action4478
From the manual ...:
  • DTC P1249 indicates that the PCM detected the turbo was overboosting.
  • Possible causes:
    • short to ground
    • plugged WGC hose or port
    • WGC solenoid
    • WGC actuator
    • WGC valve
    • damaged PCM
  • Perform KOEO On-Demand Self Test.
Is DTC P1690 present?
Old Apr 2, 2008 | 10:35 AM
jwhitetail's Avatar
jwhitetail
Some programmers throw this code. When you run truck hard, from high boost. I can clear this code and put truck on stock setting, and this code does not come up again.
Old Apr 2, 2008 | 03:04 PM
jrf250's Avatar
jrf250
I put My truck on stock tune about a 6 weeks ago to check fuel millage(thought that was killing my millage). Checked codes and it was there. Was not there when I put it back to stock. Truck seems to run fine, just have poor fuel millage. Checked and changed fuel filter,changed air filter,changed oil, and cleaned EBPV and tube.
kupaa
Sep 27, 2007 11:43 AM
blksiryder
Aug 22, 2007 09:06 PM
SBChero
Jun 6, 2007 04:23 PM
sgrol
Apr 12, 2007 09:38 PM
mtgrzlyman
Apr 17, 2006 02:04 AM
