Wastegate and P1249 code
Old Apr 9, 2007 | 08:56 PM
sgrol's Avatar
sgrol
I noticed, on the Autoengenuity Help link, that the wastegate is supposed to be near 0 when idling. Watching on my AE screen, mine stays around 87% at idle and goes down when I get on it. I get a consistent P1249 and this may be the reason why. I have followed the diagnostics checks for the wastegate and have found nothing wrong. Anyone know where the wastegate duty cycle value is generated. Is it internal in the PCM or a sensor somewhere. I am leaning toward a bad PCM but want to make sure before I condemn it. Other than the code the truck runs and performs fine.
Old Apr 9, 2007 | 09:03 PM
Zwalters's Avatar
Zwalters
Don't mess with what isn't broke, unless your breaking it to have fun or make it better.
Old Apr 9, 2007 | 09:05 PM
Pocket's Avatar
Pocket
I've also wondered. My wastegate duty cycle stays at 99% no matter what. It has never thrown a code or been an issue.
Old Apr 9, 2007 | 09:07 PM
Zwalters's Avatar
Zwalters
Me too, never heard of anyone else that had it say it was a problem, let me know if you find something out.
Old Apr 9, 2007 | 09:14 PM
sgrol's Avatar
sgrol
Excellent point, however it bugs me when something isn't right. I'm always up for a challenge.
Uzumati's Avatar
Uzumati
From the service manual:
When pressure is supplied on the red hose going to the actuator (solenoid NOT energized (0%)) the valve will open, dumping boost. When low or no pressure is on the red hose going to the actuator (solenoid is being energized (99%)), the valve will stay closed.
The PCM commands duty cycle based on MAP readings compared to BARO readings to determine boost (Manifold Gauge Pressure in AE)
Old Apr 9, 2007 | 09:16 PM
sgrol's Avatar
sgrol
Curtis and Zwalters, Do either of you see the P1249 code? It doesn't lite the MIL but will show up on a scanner.
Old Apr 9, 2007 | 09:21 PM
Zwalters's Avatar
Zwalters
I'll look tomorrow. I haven't pulled any codes for awhile.
Old Apr 9, 2007 | 11:06 PM
Pocket's Avatar
Pocket
No, I've never pulled the P1249 code. I use AE just so you know.
Old Apr 12, 2007 | 09:38 PM
Zwalters's Avatar
Zwalters
Nope no code!
Ryanizbrand
Mar 27, 2017 05:56 PM
lostfish
Oct 29, 2016 11:17 PM
macks405
Oct 21, 2013 10:41 PM
blksiryder
Aug 22, 2007 09:06 PM
