steering stabilizer help
Old Apr 1, 2008 | 09:29 PM
fords all the way's Avatar
fords all the way
hey i have a 1994 f150 its 2 wheel drive i have the stabilizer kit to fit it but i have no clue on how to install it i know its prolly the easiest thing in the world to do but if anyone can give me a link or some help it would be greatly appreciated thank you
Old Apr 1, 2008 | 11:09 PM
BChance's Avatar
BChance
what kind of kit? U bolt mount style (aftermarket add-on)or stock replacement?
Old Apr 2, 2008 | 05:10 AM
TexasGuy001's Avatar
TexasGuy001
I have a Rancho steering stabilizer. I installed when I had 32x11.50x15 tires. I have since gone back back to near stock, but decided to leave the stabilizer on there, since it was already there. I had to drill 2 holes in the bottom front of the crossmember under the motor. Be carefull and watch out for power steering lines. My truck has the low pressure return line routed in that area. Its something do to with super cooling. My previous truck did not have the power steering lines there. Then the Ubolts that come with the kit go on the passenger side tie rod. The only real hassel is drilling the holes and getting the shock not to twist when tightening up the nuts on the end. Also, position it so that the shock is half way in/out and make sure your truck's wheels are straight. Otherwise you won't be able to turn all the way in both directions with out it the shock bottoming out of over extending.
vento
Dec 4, 2009 01:00 PM
MeyerzF350
Mar 11, 2008 07:16 PM
PowerstrokeJunkie
Jun 14, 2007 11:31 AM
jake00
Dec 2, 2006 06:23 AM
4.9LFord
Apr 10, 2005 04:57 PM
