Poor Mpg
Old Apr 1, 2008 | 08:32 PM
Hellonwheels's Avatar
Hellonwheels
Thumbs down Poor Mpg
I have a 92 F-350 with a naturally aspirated 7.3 and an e4od with 4.11 running gear. I drive like a grandma and still only get bout 13 mpg. It has 180000 miles on it now. My dad said that the best he has got was 16 mpg is this normal?
Old Apr 1, 2008 | 08:43 PM
fire7882's Avatar
fire7882
4.11 gears are holding you mpg down. I have a c6 and 4.11 gears and get 11.
Old Apr 1, 2008 | 09:36 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Sounds a little low with an E4OD.
Old Apr 1, 2008 | 09:46 PM
fire7882's Avatar
fire7882
Any smoke??
Old Apr 1, 2008 | 10:08 PM
TheBlueMule's Avatar
TheBlueMule
I would kill for 13mpg.
Old Apr 1, 2008 | 10:31 PM
newr's Avatar
newr
A couple basics come to mind
When was the last time the injectors were serviced?
Do you know what your exhaust gas temp is? (Timing?)
What kind of milage are you expecting, or working towards?
0.02$ from the peanut gallery
Old Apr 1, 2008 | 10:46 PM
RCrawler's Avatar
RCrawler
The best I've ever been able to get with 4.10 gears is 14 mpg on flat ground, trying to stay below 60. Around town and on the highway, I consistently get 11-12 mpg. But the injectors need to be replaced.
Jason
Old Apr 1, 2008 | 11:05 PM
David85's Avatar
David85
What sort of driving cycle are we talking about here? short trips? average speed? distance?
Old Apr 2, 2008 | 01:07 AM
tbone91's Avatar
tbone91
With my 91 dually with an E4od, I get as bad as 11 in the city to as much as 18+ at 55 on the interstate (it's hard to drive that slow, though).
Is the air cleaner clean?
Is there a noticible diesel "rattle" when you start it cold which goes away after it warms up a bit? That would indicate that the timing is "about right".
Old Apr 2, 2008 | 11:03 AM
ned37's Avatar
ned37
i routinely get around 18mpg with my 92 e4od 4x4 with 4.10 gears. most of my driving is off the interstate, keeping the tach at or below 2000 rpm.
Old Apr 2, 2008 | 12:03 PM
fuzzy1626's Avatar
fuzzy1626
I'am sure my turbo makes a difference but I get 15 to16 around town and 18+ interstate at 65-70. These #'s are empty.
Old Apr 2, 2008 | 12:41 PM
archangel's Avatar
archangel
Mine has (as far as I can tell the original injectors), E4OD, 3.55:1 rear end gear, and most likely over 200,000 miles on it, and I get 13 mpg in the winter with a few thousand LBS of snow in the bed, 1/3 high speed freeway driving, mirrors out, the radiator grill blocked off, and my foot in the throttle enough to keep up with most traffic.
In the summer I got 15+ but not much steady freeway driving and, as always, with my foot in it more often than not.
I'd bet on 18+ish if I were going 55 on the freeway maintaining a steady speed, and with those huge mirrors on both sides folded in and a bed cover or camper shell even with the roof.
Those big mirrors, huge open grill, and open pickup bed, slow you down and eat up fuel with drag big time.
Blocking the grill has not caused me any engine temp problems so far, but I don't pull any loads, much less any heavy loads.
Also, those 4.11:1 gears keep the rpm's up much higher than needed for good mileage as they were optioned for pulling heavier loads and higher CGVW ratings, not getting good mileage.
I also saw a guy at the shorewood Home Depot that made a shell that started even with the roof of the cab but curved down to even with the closed tail gate, and I'll bet that would be better than a standard straight shell or bed liner!
This summer I think I'll make one like that myself.
Old Apr 2, 2008 | 01:26 PM
David85's Avatar
David85
something like this?
EVWORLD FEATURE: Streamlining Light Truck Fuel Economy:PICKUP | TRUCK | STREAMLINE | TEXAS | NEW MEXICO | KNOX | TOYOTA
Old Apr 2, 2008 | 09:40 PM
harleyjohn45's Avatar
harleyjohn45
I think your milage is about like mine. its poor, but better than a 460 ford.
Old Apr 3, 2008 | 11:05 AM
Breech's Avatar
Breech
I get around 13-14 with mine but I have no overdrive and 4.10 gears so she's wound up pretty good at cruise speeds. You probably don't get into 4th gear too much around town so 13 isn't that far off. If it doesn't improve much on the freeway then you may have something goin on.
