Show 'em off
Old Feb 3, 2009 | 06:04 PM
  #211
CDF302v8's Avatar
CDF302v8
Originally Posted by fordtruckman80
Yea it is.The thing I don't understand,is the truck was ordered in Cali,one of the hottest states.Yet the truck was ordered without A/C.It was probably owner preference,and the vent windows provide enough A/C,but still.lol.
Eh, who needs A/C anyways, lol!
I'm surprised my truck doesn't have A/C, since it the the top model offered.
But i love the vent windows and the sliding rear window.
Old Feb 3, 2009 | 06:12 PM
  #212
Fordzilla80's Avatar
Fordzilla80
It was a different time back then, most trucks did not come with air conditioning, as it was an extra cost option.
Today, it's a different story.
It's only hot in inland CA in the summer, late spring and early fall. Along the shore, it rarely gets any hotter than 85 degrees.
And since most of SoCal is a desert, it's a DRY HEAT.
You cannot say that about sub-tropic Florida!
The Big Dummy was born in Santa Monica, and now resides about 40 miles east in bee-u-ti-ful Hacienda Heights, another of the 60 or so suburbs of LA.
Yea you got a point.
Hey,maybe you saw my truck on the lot.lol.Just kiddin.
Old Feb 3, 2009 | 06:45 PM
  #213
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by CDF302v8
I have already decoded the vin and axle code, but, can you decode the spring, and tape codes for me?
Also, what was the highest GVWR ratings on the F-150 with the 302?
Are you aware that H9 is a Limited Slip rear axle?
If the AXLE code begins with a letter: Limited Slip.
If with a number: No Limited Slip.
B = EOTZ5310B .. Front Spring / Load Rate 2650 lbs.
D = E2TZ5560D .. Rear Spring / No Load Rate listed.
After March 1981, Ford no longer lists the spring load rates in the parts catalog (the SOB's!).
If the springs part number was used before that date, I can find the load rate. After that date, I'm SOL.
This was the case originally, and today, it's the same old sad story.
Tape 2 = Regular & Super Cab.
Two stripes run the length of the upper side of the fender/door/cab corner/bedside.
The lower stripe is much thicker than the upper. Several different combo colors were available.
The GVWR depends on the TYPE-GVW code, not by the engine size.
Old Feb 3, 2009 | 06:55 PM
  #214
Fordzilla80
I had asked someone about this but I never got an answer.My axle code is 13,which means I have No limited slip.And I know it doesn't have a posi.So,does this mean that my left rear axle spins freely?And if my Right rear wheel loses traction,say if I got stuck on a wet dirt road,does that mean i'm screwed?I'm thinking so.
Old Feb 3, 2009 | 07:08 PM
  #215
Built_Ford_Tough_757's Avatar
80F100man; Were did you get those tail lights from?
Old Feb 3, 2009 | 07:18 PM
  #216
NumberDummy
I had asked someone about this but I never got an answer. You have one now.
My axle code is 13, which means I have No limited slip.
There is no such thing as a Posi, or Posi-Traction axle on any Ford.
Posi, or Posi-Traction are GM terms. Originally the term Posi-Traction was used by Packard (not a GM car!) in 1956, as this was the first vehicle to offer it (as an option).
Ford uses the term Limited Slip, which covers a wide range of axles like: Traction-Lok, Equa-Lok, whatever.
Ford introduced Limited Slip (Equa-Lok) in 1959.
Old Feb 3, 2009 | 07:25 PM
  #217
Fordzilla80
Ford introduced Limited Slip in 1959 on passenger cars and F100's initially.
Did not know that.....you learn somethin new everyday.Thanks.
Old Feb 3, 2009 | 07:30 PM
  #218
NumberDummy
Some of my posts have all sorts of Ford trivia in them...and one thing you should do is...
Read the same post after an hour elapses (the time FTE allows for editing).
I'm the editing KING of FTE, and within that hour, the entire post may be different!
Last edited by NumberDummy; Feb 3, 2009 at 07:31 PM. Reason: LOL!!! Since when do I need a reason?
Old Feb 3, 2009 | 07:37 PM
  #219
Fordzilla80
I'll keep that in mind.lol.
Old Feb 3, 2009 | 07:42 PM
  #220
CDF302v8's Avatar
CDF302v8
Thanks for the decode!!
Yup, i was aware that it is an limited slip axle.
Old Feb 3, 2009 | 08:52 PM
  #221
Old Feb 3, 2009 | 09:21 PM
  #222
displacement4me's Avatar
displacement4me
Super clean truck built_ford_tough, very nice. Whats on the lock cylinders?
Old Feb 3, 2009 | 10:49 PM
  #223
Thanks displacement4me, Yours looks good too. On the doors locks, it's a bedliner patch. I guess the previous owner did it to reduce chipping the paint if the key missed. Its cool. He did it inside on the "threshold" (Spelling? Sorry) The truck has a bedliner on it too but its a different type, its more rubber than sandy. I thing Rhyno did the bed.
Additional Info:
It has a 302 EFI, AOD Tranny, 4" Inch Rough Country lift, 15" Pacer Wheels mounted on 31" BGF All-Terrains, Bedliner, Lights mounted in the fenders, amber front/red rear, fog lamps, factory marker lamps on roof. and in shipping, a used but nice tailgate finish panel.
Future Ideas:
Installing a double/single chrome roll bar w/ off-road lights, 4x4 conversion, also changing the 4" lift to 6" lift with Sky-Jacker springs and shocks (Using existing brackets from the lift now), 35" Mickey Tompson Baja Claws mountedf on Classic Locks, finish restoring my interior colors, possible re-paint (Same colors)
Last edited by Built_Ford_Tough_757; Feb 3, 2009 at 11:03 PM. Reason: Additional Info
Old Feb 4, 2009 | 12:46 AM
  #224
colemanw's Avatar
colemanw
great truck ****
Old Feb 16, 2009 | 11:10 PM
  #225
SteveW09's Avatar
SteveW09
My first post outside of an introductory one a while ago
Here's the '80 F250 I bought Saturday for $1700:
351, 3sp auto, nice interior:
Steve
