safe rpm limit for 302
just put a tach in my old truck, and was wonder what the safe rpm limit for a 302 is?? it's a long block rebuild from a LTD with 60,000 km's on it, runs as strong as when it was new, dual 2" exaust and highflow glass packs. 2v ford carb. right now, if you hold her down, she'll shift between 4500-4900 for 1 to 2 shift in an aod tranny.. is this normal, or am i pushin it too hard??
normal driving it shifts 4000 or less
Thats normal, 6200 is high, thats a mustang it's different. The trucks are around 5500 redlines i think, I don't let mine go over 5.
Primary rig is Green Thunder:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Flowmaster American Thunder Exhaust, Sunroof, Clear corners w/ Diamond headlights, CD player with 2 10" subs and some 32" BFG Muds .
That's it for mods now, saving for a Stang. Check out my Gallery for a look-see.
The Mustang's limiter is at 6k, but it is losing power since around 5400 anyway. Like was said, it's different in a truck. The truck needs power down-low to build torque to move it's twice as heavy carcas whereas a 3500 pound Mustang can live with peak horsepower at a highr RPM.
On a side note, my friend's 550HP 331 stroker redlines at 7500 RPM.:-staun
Why don't you just buy the regular guage cluster w/ a tach and plug it in haha, the wiring is there.
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Flowmaster Exhaust, Sunroof, Clear corners w/ Diamond headlights, CD player with 2 10" subs and some 32" BFG Muds .
Justin - One Happy FTE Member
Reving to 6000 would be a bit high. for a 3800 peak HP.
A different cam would change the peak HP rpm.
Shifting at 4000 to 4500 should be good for a 3800 peak HP.
Of course, this depends on the difference between the gears also.
To really figure it out you would need to know what the driving needs are HP and Torque curves and the RPM drops between the gears.
But getting back to the question, the shift points sound good.
screamersusa
08-07-2012 11:46 PM
TheKirbyMan
18
01-10-2012 01:04 AM
72earl302
06-03-2011 08:14 PM
MustangGT221
37
03-28-2003 01:16 PM
