well thanks guys and now i have to find a mass air flow sensor. or try to clean it, i bought some spray just for mass air flow so im going to try it.
The MAF sensor is located in the air cleaner housing closest to the throttle body. You have to separate the housing from the tube and then separate the inner section. (inner and outer). The MAF sensor is held on by two torx screws.
Spray clean...and wait to dry. Then assemble...and feel the difference.
thankx again i cleaned it now it good and i can feel the difference. sweet.
now im think im going to buy the throttle body spacer, does anyony have one or tell me if they work well or a wast of money?
George dont waste your money on the throttle body spacer unless you also plan on replacing both of the muffler bearings and the referberator modulater .
Seriously do a search on the spacer and you will see there is not any inprovement on mpg's on the superduties.
hello and can some one help me, my 2000 f-350 4x4 wont disengage on the pasanger side, the hub is on auto and so is the drivers side, the drivers side spins free but the pasanger side is tought to spin. can some one tell me whats wrong. thanks
