Shock Recommendation
Old Mar 27, 2008 | 07:42 AM
Suzie68's Avatar
Suzie68
I am looking at getting new shocks for my truck, and am looking for opinions/recommendations on types and brands.
My truck is a 04 Screw FX4. I am looking for a smooth non jarring ride. The only offroading I do is into the woods during hunting, and ocassionally hauling wood (not very often). 99% of the drive is on the road. I do tow a bit (pop up camper, 2-4 place snowmobile trailer)
So lets here what you reccomend.
Thanks
Jon
Old Mar 27, 2008 | 07:54 AM
aleopo1's Avatar
aleopo1
I just got some new Bilstein shocks a few months ago after my stock shocks were almost completely shot. The ride improved greatly, I couldn't feel half the little bumps in the road that I used to. They're great. I'd highly recommend them, and they have a lifetime warranty.
Old Mar 27, 2008 | 08:51 AM
BrianFX4's Avatar
BrianFX4
I replaced my stock shocks and struts with the Rancho RSX9000XL's. They have a 9 way adjustment for those times you do go offroad. I set mine for how I like it to ride on the street and I never adjust them unless I go off road. The ride is great and a couple times a year they do a buy 3 get one free deal.
Old Mar 27, 2008 | 11:27 AM
bansheeduner's Avatar
bansheeduner
bilstiens are the best they tune each shock to your truck. the shocks arent universal like rancho and all those other brands they are made for your truck and your truck only by far the best shocks ever
Old Mar 27, 2008 | 04:15 PM
Big Bad's Avatar
Big Bad
I've had the best luck with Tokico shocks (and struts). Bilstein tends to valve their shocks too stiff in my experience, maybe ideal on a BMW with low profile tires but hardly what I want in a truck. I've also been unimpressed with Edelbrock IAS shocks.
Don't waste your money on shocks hoping for a better ride if your stock ones aren't worn out, because they won't provide it. The vehicles ride and handing quality is determined much more by spring rates, spring location, sway bar diameter and bushing quality than the brand name of the dampeners. The stock shocks are actually excellent pieces if the rest the suspension is still stock.
Old Mar 27, 2008 | 06:01 PM
MBBFord's Avatar
MBBFord
Stock shocks need to be replaced around 30K miles.
They are completely shot by 50K.
In your situation, I would seriously consider the bilstien shocks with adjustable lift ( 0-2"). I would put them at
1.5"-2" of lift and get an alignment.
These trucks look great when leveled, and you would get a lift and new shocks at the same time(2 birds one stone).
IF not Bilstiens, then Ranchos.
I have 9000s and they work great, and I like them when I tow also.
Old Mar 27, 2008 | 07:24 PM
F0rdzTuff's Avatar
F0rdzTuff
Question
If you use the shock to lift the truck, then aren't you "stretching the springs"? That doesn't sound right...in the long run at least.
Old Mar 27, 2008 | 10:31 PM
VFR_Man's Avatar
VFR_Man
Wait... we just went over this a couple weeks ago, dint we?
https://www.ford-trucks.com/forums/7...es-struts.html
Old Mar 28, 2008 | 11:48 AM
MBBFord's Avatar
MBBFord
To answer your question: NO
Obviously you don't know how the shocks work, or a leveling kit.
Please research before posting.
Old Mar 28, 2008 | 11:50 AM
bansheeduner
how can u obtain the lift on the bilstein the upper section just compresses the coil we just installed a set on a 04 4x4 and couldnt get the plus 2
Old Mar 28, 2008 | 12:23 PM
MBBFord's Avatar
MBBFord
Not all bilsteins have the adjustment.
You have to order them specificly, not just the regular Bilsteins.
The bottom of the shock extendeds 0,1", and 2"s giveing the lift, so no stretching the spring.
Old Mar 28, 2008 | 01:29 PM
bansheeduner
yea it is a 2 position clip plus 0 or plus 2
Old Mar 28, 2008 | 01:37 PM
F0rdzTuff's Avatar
F0rdzTuff
Angry
Look *****, I was ASKING aquestion, not making a statement. Perhaps they never taught you the meaning of a "?" mark in elementary school, but that isn't MY problem.
Old Mar 28, 2008 | 01:51 PM
F0rdzTuff's Avatar
F0rdzTuff
Question
Ok, this a QUESTION for someone else, or for you if you want to answer it. If the lift is achieved through the bottom of the shock, aren't you putting the weight of the front end on the shock posts moreso than the springs?
Feel free to be an *** again if you'd like. I'll just reply in the same fashion, which isn't good for the rest of the people trying to read this forum. However, I'm a retired Infantryman, so I'm a little hard-headed from time to time...
Old Mar 28, 2008 | 02:41 PM
MBBFord's Avatar
MBBFord
If you're worried about other people getting info, then shut up!
