Shock Recommendation
Old Mar 28, 2008 | 02:47 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Puh-leeze...YOU two need to stop now, or you both get time off.
Old Mar 28, 2008 | 05:32 PM
Big Bad's Avatar
Big Bad
Originally Posted by MBBFord
Stock shocks need to be replaced around 30K miles.
They are completely shot by 50K.
Nine times out of ten, absolutely dead wrong.
Old Mar 28, 2008 | 06:57 PM
F0rdzTuff's Avatar
F0rdzTuff
There's a bug in your computer
I agree with the last post of the shocks being completely blown at 50,000 miles. It depends on how you treat your truck. I can blow a set (like I did on my 2002) in a couple of weeks if I wanted to.
Old Mar 28, 2008 | 07:19 PM
IB Tim's Avatar
IB Tim
IMO stock shocks last about 10/15k ....that is on a good day.
Old Mar 28, 2008 | 07:27 PM
F0rdzTuff's Avatar
F0rdzTuff
Talking
SERIOUSLY?!? And I thought MY roads were bad...
Old Mar 28, 2008 | 08:09 PM
smokestone52's Avatar
smokestone52
Here I agree with Tim, which I don't do often. Stock shocks will last if you use your truck as a soccer mom suv. But if you haul, or tow the stock shocks will not hold up (about 10,000 miles).
I am way past needing shocks, so I have been lurking here.
Thanks for the info so far. I am leaning towards the Bilsteins.
But I will listen for awhile.
Old Mar 28, 2008 | 09:34 PM
MBBFord's Avatar
MBBFord
Did you pull mutliple shocks off to know this....?
I did, and every stock shock I pull off is complete junk.
Last time was on a 04 F150 with 70k miles. Once the shocks were off the truck and compressed they didn't even try and come back out!
That was a lot of hwy miles with very little towing.
So, shocks need to be replaced around 30,000 miles b/c they aren't doing their job anymore.
Old Mar 29, 2008 | 01:30 AM
bowhunt24's Avatar
bowhunt24
Originally Posted by F0rdzTuff
Look *****, I was ASKING aquestion, not making a statement. Perhaps they never taught you the meaning of a "?" mark in elementary school, but that isn't MY problem.
Atta boy....some guys get off way too much trying to be a bad a$$ on an online forum....c'mon
Old Mar 29, 2008 | 03:02 PM
Big Bad's Avatar
Big Bad
Yes, I have pulled plenty of shocks. I have seen 100,000 mile stock shocks with perfect operation. I have yet to see an unabused, non-defective stock shock gone at 30K.
Old Mar 29, 2008 | 03:50 PM
pilot10's Avatar
pilot10
Counting back through the past 30 years I've changed shocks more than a dozen times on about that many vehicles. Certainly nothing special but I know each and every time I replaced the shocks the vehicles ride was improved either moderately to so significant it was like a new vehicle.
Shocks are wear items- They wear out. Of the ones I did there were three sets where the shocks were completely flat- no rebound at all. When I replaced the heavy-duty OEM shocks on my old '01 f150 4x4 at 70k I did a comparison squish test and didn't see much difference. Thought I was replacing too early. I've got to say after replacing them I was laughing out loud because of how improved the ride was.
I would replace the OEM shocks at the first tire change (45-75k) and then every couple tire changes. But that is just me.
Some people will push the wear item until there is absolutely no life left- which is fine, it's a machine.
I use the vehicle for fun- I want the ride to the playground to be enjoyable. I'll pay extra to keep the vehicle running in perfect order. If it were a work truck I would do scheduled maintenance and only repair/replace when necessary to keep the vehicle useful.
Anybody try Monroe reflex on these trucks? They are the ones that made me grin from ear to ear on my 01.
Tim
Old Mar 29, 2008 | 10:30 PM
4rdfvr's Avatar
4rdfvr
I just got thru replacing the shocks after 42k miles, with the bilsteins 5100 series. I used the second highest position setting on the front shocks to get a level ride height. Got a great deal at topguncustomz. ***Please do not try to install the coils yourself, have a shop install for you. I tried with the auto parts spring loaner tool??? The coils need to be compressed more to install if you are going to use the level ride height location. the guy at the shop charged me $40 and he told me to NEVER try it yourself. I couldnt agree more. Yes the coil will have some preload. I called bilstein and asked of this they said the shocks were made in consideration of this. I took it for a ride and i can say i have noticed a difference already. I need to see how it feels on the freeway. I also replaced rotors(powerslot) and hawk pads.
I also replaced my excursion with bilstein and yes what a difference. I had the edelbrocks and they lasted soso.
Old Feb 11, 2009 | 03:50 PM
boomer08's Avatar
boomer08
What if you want to change the setting on the bilstein from say the #2 position to the #1 position what is the process in doing that compared to the Rancho of just dialing it down?
Old Feb 11, 2009 | 05:19 PM
  #28
Catmonkey's Avatar
Catmonkey
Bilstein's are only adjustable as to stock height or a 2" lift. They valving is not adjustable. The way Bilstien sets it up is what you got. Rancho's QuickLift only offers a raised spring perch (no stock height with QuickLift) which gives ~2" - 2.5" of lift. The adjustablity is in the shock valving for rebound and compression. I had a lot of questions about the Rancho's before I installed them and it wasn't clear to me either. I called their tech line and got the info and then ordered them. They've only been on a few days, but I just made a round trip of 60 miles on beat-to-hell I-10 and I like 'em.
