Sponsored by: Auxito
p170 and p171 codes?
Old Mar 26, 2008 | 10:46 PM
ford2002f150's Avatar
ford2002f150
(ive got an 02 F150 4.2L)
My Check Engine light came on a few thousand miles back. i unhooked the battery but the light came back on a few thousand miles later and i started to not get quite the same gas mileage. so i went to discount auto parts and they gave me those codes. the guy told me i probably just needed to clean the sensors. i took a look and they didnt look all that dirty or rusted or anything.
so i started reading about these codes online and ive read a few things that said those codes for an OBD-II vehicle means youve got a vacuum leak, or the fuel system is clogged, etc... and that the first place you should look is to see if the PCV elbow/hose has a hole in it or if the MAF sensor is dirty. is that right? what should else should i look for? and where is the mass air flow sensor?
thanks....
Old Mar 27, 2008 | 12:07 PM
Bobby82490's Avatar
Bobby82490
Yeah i would check those 2 things first. The MAF is in the intake..if you take your air filter out and look in the tube you will see it. I would check the PVC hoses first though.
Old Mar 29, 2008 | 12:13 AM
fordborn's Avatar
fordborn
both of those codes are related to bank 1. 170 is Fuel Trim Malfunction Bank 1 and 171 is system to lean Bank 1.
Old Mar 29, 2008 | 08:12 PM
stanlucky's Avatar
stanlucky
any sensor can give a 171. Check the manifold for leaks, both intake and ex. clean and or replace the plugs MAF ect. check resistant on the plug wires or cops.
WatsonR
Jul 27, 2024 12:58 PM
RSCHAP1
Sep 6, 2016 04:56 AM
jdavidsmi
Modular V10 (6.8l)
13
Jun 4, 2016 10:18 AM
lakewood
Apr 25, 2013 09:59 AM
ford150ford350
Mar 3, 2013 03:28 PM
