changing ring gear
Old Mar 26, 2008 | 10:05 PM
lifted79ford's Avatar
lifted79ford
changing ring gear
just wondering on how you change out a ring gear on a 79 f150 4 speed. it has the 351 modified motor. i can just get a new flywheel but a new ring gear is cheaper.
Old Mar 26, 2008 | 10:50 PM
whalerron's Avatar
whalerron
Ring Gears are easy to replace.
1) Rest the flywheel machined side down on a piece of plywood.
2) Use a hammer and punch to knock the ring gear off of the flywheel. You will need to work your way around the flywheel as you hammer off the gear.
3) Put the flywheel in a freezer for an hour. Put the ring gear in your oven at about 400 degrees for 15 minutes ( Make it the last 15 minutes that the flywheel is in the freezer.
4) Take the flywheel out of the freezer and rest in on a piece of plywood with the machined surface up.
5) Remove the ring gear from the oven and place it on the perimeter of the flywheel.
6) Use the hammer and punch (brass punch would be best) to drive the ring gear into position against the shoulder on the flywheel.
You don't really need to use the freezer/oven trick but it does make the job easier.
- Ron
Old Mar 26, 2008 | 11:30 PM
OldMetal's Avatar
OldMetal
https://www.ford-trucks.com/forums/5...heel-help.html
This is being discussed here.
PRIMERED79 SHORT BED
18
May 13, 2012 10:59 AM
nickelndime79
Jul 15, 2011 10:21 PM
79f-250custom
Jan 12, 2007 11:38 AM
wook540
Jul 27, 2004 09:44 PM
