351w police intercepter?
Old Sep 17, 2002 | 09:58 PM
knightshield's Avatar
knightshield
This Summer I bought a 1977 F-150. A previous owner told me he put a 351w police intercepter in it. He said the engine came out of a cop car.
He could not remember the model or year of car it came out of. It runs good, lots of power and only uses/leaks about a 1/2 qt. of oil between changes.
My question is can anyone help me identify the engine? It is a 351w, it has gray valve covers, a gray oil pan and the oil pan has 2 drain plugs! One at the front of the pan and 1 at the back.
Any help is appreciated.
Old Sep 17, 2002 | 10:28 PM
airharley's Avatar
airharley
Casting #'s would be great at this point. Check the block and intake #'s and post them on here so we can decode them.
Old Sep 18, 2002 | 11:11 AM
loudfords's Avatar
loudfords
Sounds like the 80's Crown Vic/Grand Marquis 351W. I have most of one left over as you describe it. Does it have an aluminum 2 bbl intake on it? If so it likely originally had "VV" variable venturi junk on top from the factory.
Old Sep 18, 2002 | 09:31 PM
knightshield
Where exactly are the casting numbers located on the block?
I have a 1982 F-150 with 351w that has that crappy variable venturie carb.
Thanks guys, and I will try to find those numbers.
Old Sep 19, 2002 | 11:07 AM
loudfords's Avatar
loudfords
Block casting number will be just above the starter. Intake casting number should be on one of the intake runners in front of the carb/vv. A Ford 2bbl carb bolts directly in place of the vv junk, BTW.
Old Sep 19, 2002 | 04:26 PM
knightshield
Thank you. I will look for the numbers . So it is not a major job to replace that carb? Cool.
If your high beem switch is not a button on the floor you ain't got #####.
Old Nov 14, 2002 | 09:07 PM
fordifieds's Avatar
fordifieds
Old Nov 14, 2002 | 09:45 PM
fordifieds's Avatar
fordifieds
I just took a 351police interceptor out of the folks cop car. It was an 84 crown vic. Sounds like you have the same thing with the double sump oil pan and VV carb on it. I took mine apart just to see if anything was diffent about a police interceptor. ie heads or block. But found nothing to be very different than any stock 351. I know that the old boat would move about 135mph with 120,000 on the car. I was disapointed hoping to find a good set of heads or a roller block but found nothing of interest. The only cool thing I saved off the car was the awsome spotlight and the factory 140 speedometer.
Fordifieds
Old Jul 5, 2003 | 09:19 PM
1975 f150 360's Avatar
1975 f150 360
the police interceptor should have more compression. i have a 352 police interceptor and the heads are different and has more compression does anybody know the stock horsepower for a 352 police interceptor and torque
1975 f150 360
1965 galaxie 352 police interceptor
minerman
Jul 5, 2010 01:17 PM
wadar1969
Jun 26, 2010 08:03 PM
diiquality
Aug 31, 2005 12:47 PM
76250highboy
Feb 1, 2005 01:51 PM
