spark plug
Old Jul 4, 2003 | 07:37 PM
Chris_ce's Avatar
Chris_ce
spark plug
got a spark plug that won't come out.got it to turn a little but now wont go back in any either so i'm thinking really corroded
or cross threaded.had two like this but finally got the other out .
whats the best way to remove this plug without breaking it or taking it apart.
Old Jul 4, 2003 | 07:55 PM
Torque1st's Avatar
Torque1st
Posting Legend
spark plug
That does seem to be a common shop problem with all of these garbage aluminum head engines.
All of those plug threads need to be looked at. They will all probably have to be heli-coiled. Take the heads off and get them to a machine shop. Next time buy only vehicles with iron heads. Aluminum is worthless in a daily driver automotive engine. For information on how to remove the heads post in your appropriate engine forum.
Old Jul 4, 2003 | 08:48 PM
Chris_ce's Avatar
Chris_ce
spark plug
sorry should have stated in the first post that they are cast iron heads.87 351w ho.just bought this bronco to pull a camper.
the plugs are split fires which in my opion are a crock of.
Old Jul 4, 2003 | 09:31 PM
Torque1st's Avatar
Torque1st
Posting Legend
spark plug
That just does not happen often with iron heads. Unless someone is really sloppy, -but then someone that would put in splitfire plugs...
Sounds like you need to talk to the people in the Windsor forum. Those heads will have to come off and be reworked.
Sorry about the gripe with aluminum heads, it is a pet peeve of mine.
Old Jul 5, 2003 | 12:01 AM
Mil1ion's Avatar
Mil1ion
spark plug
Squirt a little transmission fluid around the threaded area and let it sit a few minutes then try again
Old Jul 5, 2003 | 10:20 PM
Chris_ce's Avatar
Chris_ce
spark plug
Would starting it up and letting it get warm help any?
kyacklich
28
May 14, 2024 06:08 PM
skeetseats
17
Feb 20, 2017 11:08 AM
Steven Adermann
Apr 30, 2016 08:47 AM
kermmydog
17
Mar 2, 2013 03:19 PM
JTHill24
Aerostar
24
Jan 27, 2009 12:44 AM
