351w rebuild
Old Apr 25, 2012 | 08:45 PM
Joshrabbitt14's Avatar
Joshrabbitt14
351w rebuild
I am beginning to rebuild my old 87 with the carbureted 351w and it's been sitting for over 10 years and I want to do a complete rebuild. With the rebuild I want to use performance parts and get good power for fun but keep it somewhat reliable for my daily driver. What do you guys recommend to put into my motor?
Old Apr 26, 2012 | 06:31 AM
critterf1's Avatar
critterf1
How much do you want to get out of it and how much do you want to spend?
Old Apr 26, 2012 | 01:44 PM
Joshrabbitt14
I'm not to worried about money and I want to get a good amount out of it but still keep it reliable for my DD
Old Apr 26, 2012 | 07:38 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
Assuming it needs a rebore, some hypereutectic flat top pistons. The stock crank and rods are fine, get them ground/balanced and upgrade the rod bolts. A cam with less than 220 degrees duration @ .050" and closer to 210 will be best in a DD.
Heads are where the power is, a good pair of aftermarket heads is your biggest bang for the buck. Aluminum heads will handle a higher compression ratio and run cooler.
Then a Performer RPM or Weiand Stealth intake and good long tube headers.
Old May 2, 2012 | 09:14 AM
Flathead Red's Avatar
Flathead Red
Try this website: Northern Auto Parts: Home
They have a good selection of complete kits for engine rebuilds.
Red
Old May 2, 2012 | 09:19 PM
meric1887's Avatar
meric1887
What type of vehical is it goin in
Old May 6, 2012 | 07:50 PM
Joshrabbitt14
Its going into an 87 f350
Old May 7, 2012 | 09:28 PM
Joshrabbitt14
These heads any good?
Edelbrock 5023 - Edelbrock E-Street Cylinder Heads - Overview - SummitRacing.com
mikepedersen17
Nov 24, 2010 09:46 PM
ozblitz
Jan 19, 2010 01:21 PM
Redneck1465
Jan 19, 2009 01:03 PM
Prodigy223
Jan 20, 2004 08:27 PM
rchenifo
Mar 6, 2003 06:01 PM
