Frankenstein Drivetrain Issues
Old Jul 28, 2008 | 01:26 PM
  #46
FTE/PARTS-GUY's Avatar
FTE/PARTS-GUY
Former Vendor
there is no pic in catalog. the moderately brkt is a POS small little L shape piece of metal not to impressed with it. Maybe Steve can snap a picture of the big boy kit he installed.
that baby represents!
Ed
Old Jul 28, 2008 | 02:02 PM
  #47
Tremclad's Avatar
Tremclad
I definitely think it's a beast that will fix the problem for good, I'll take some pics tonight when I try to get a bit more done.
Old Jul 29, 2008 | 04:36 PM
  #48
Tremclad's Avatar
Tremclad
Here's some pics of it installed. Of course I gave the surrounding areas a good coat of my favourite, flat black rust paint.
Old Jul 30, 2008 | 07:29 AM
  #49
Tremclad's Avatar
Tremclad
I started reassembling everything last night. A few issues.
1) The plastic bushings, C9AZ-2474-A, that go on where the pushrods meets the brake and clutch pedals, fits only the brake. The clutch pushrod bushing is smaller, not sure if it's relevant, but the factory clutch one was gray versus the black colour that is the old brake and C9AZ-2474-A.
2) E3TZ-7541-B .. Adjustable Clutch Master Cylinder Pushrod. Absolutely no idea how to remove the old one. I removed the spring clip from the clutch master cylinder, but I couldn't see how it removed the internal blue plastic piece. So I just left it, I'll revisit it if I find the clutch needs adjustment.
3) The screws that hold the steering column baseplate to the firewall aren't long enough. The reinforcement plate is only 3/16" thick at the most, but it's enough to keep the screws from engaging no matter how mcuh force I push everything togethe. So I'll just go out tonight and get some longer ones that can still catch the firewall.
Old Aug 1, 2008 | 08:14 AM
  #50
Tremclad's Avatar
Tremclad
Everything is complete and back together. LMC truck calls out the correct bushing for the clutch pushrod so I'll just get it from them. I bought longer screws for the steering column base plate and the truck fired up fine last night and shifted gears and the brakes felt alright. Case closed.
Old Aug 4, 2008 | 06:37 AM
  #51
cfrives3's Avatar
cfrives3
Sweet. I didn't even know they made a kit for that. Mine went out around the clutch reservoir about 50 miles away and pulling a trailer. I drive a truck for a living so I got it where I was going and a buddy of mine and I fabbed up a piece of reinforcement and welded it up- no problems since. Glad to see you got through it.
Old Sep 10, 2008 | 01:57 PM
  #52
MK_61701's Avatar
MK_61701
Sad, ain't it...
I was a Ford partsman for 35 years. I saw this chit coming in the 1980's, and knew what the outcome would be.
Dealers would have to hire computer certified techs, and that would leave us old pharts out in the cold...we either had to learn the system, or....
So...here's what you have today...a few 'puter savvy old pharts who have been around for decades, or mostly new hires, most of which can't tell an older Ford from a CHEVROLET!!
Since no real effort is needed today to come up newer part numbers, and the new hires don't know diddly squat about older Fords, now you know why I have 13,500 + posts on FTE in 17 months.
Ppl need parts for these older vehicles, and get little or no help from the dealers.
Their usual excuse: "Sorry, all the parts are obsolete."
Uh huh...how do they know that without lookin' in the books? How many really know how? How many give a chit?
The passion is gone, most are there today only for a paycheck, and little else.
Rant concluded...for now!
I am new to this site. I read with great interest with what you said and agree. However, not all parts pc savvy are that way. I am certified pc/former parts/communications man when I worked at CAT and handled 4 of their facility's nation wide. I am not a mechanic by no means. However I believe
in customer satisfaction comes first at all costs. If I did not know the answer I would research and make calls for all my contacts at CAT. They never
had to second guess my promise they knew what ever their needs were,
I would meet them all every time. So lack of knowledge of car or engine
or anything that is being sold to a customer is no excuse for not being
able to take care of the customer. If you dont take care of them, they will go else where. Its not lack of knowledge, its laziness from the new breed of
people in this world, lack of self pride to do what is needed to maintain
the pride in ourselves and confidence of the customer. Just my views on this.
Old Sep 14, 2008 | 04:21 PM
  #53
MK_61701's Avatar
MK_61701
M/C and Firewall Torn
Hello Guys,
Just got back on and was reading the posts and viewing the pictures from
Tremclad on his cracked firewall. Mine is the same way I noticed yesterday,
I had someone push on the clutch peddle and brake to see the M/C move
about a 1/2in to 3/4inch outward and downward. The crack on mine is
above the M/C brack mount to the firewall and travels half way down
on the right side when your looking at it. Am I to understand that could
very well be the reason the clutch is extremely hard to engage in order
to shift gears? Also, I am wondering if just maybe the push rod joined to
the M/C is not bent and needs replacement? I am wondering if I should not
replace the M/C when I can. I do not think mine is adjustable nor do I have
a bleeder screw? If anyone can tell me straight up cause I called around
to all Ford Parts Depts. No one knows for sure? And how big of an area of
metal plate do I need to reinforce this firewall, I need to get this fixed before
it becomes undriveable. Info on stats of truck below. Thanks.
M.K
P.S Do i need to post a few pics for others to see?
88 Ford 150
2Wd
dual tank
Regualr cab
6 cylinder 4.9L straight engine
This clutch system is Hydralic I believe, does this still use a push rod of type?
Also, can anyone give me an idea why with the defrost running "it works
good throws out heat" but the passenger windows stay fogged up?
The duct work under the dash has a slight gap where air was leaking. SO
I zipped a few machine screws and used black silocone to seal it up but
it seems its not defogging very well. Any ideas????
Old Sep 14, 2008 | 05:05 PM
  #54
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
A) Now that you KNOW your firewall is torn get your buddy to make up an 1/8" plate that reinforces the area and use some weldable sealant iF you're going to Mig it in place. Make sure you catch the transmission tunnel and the bottom of the cowl box as shown above.
You probably also need to replace at LEAST the lever to M/C pushrod clip.
B)There are 2 doors in the heater ductwork. first is the "blend door" in the heater core plenum. The other is the defroster door farther along in the ductwork.
This function is controlled by a cable that clips to the front of the heater box behind the glove compartment. if this clip comes loose, or the cable sheath slips in the clip, 'defrost' will not function properly.
The side window defrost was never too good in my truck.
Old Sep 14, 2008 | 05:46 PM
  #55
MK_61701's Avatar
MK_61701
Thanks. I take it is this is not a long difficult fix to do? Will this fix the problem of laying on the clutch to get it to shift into gear? Also, was
think of bolts instead of welding as it is difficult to find a welding place or
anyone who has access. Did you buy a reinforcement kit or make your
own? And how thick of steel should be used? I called advanced Auto
today thinking I should replace the M/C if I need to, they have them
but do not sell any push rods. I dont think mine has an adjustable one
as I have read on here and no one can tell me for sure?
Old Sep 14, 2008 | 06:27 PM
  #56
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Originally Posted by MK_61701
Thanks. I take it is this is not a long difficult fix to do? (1)Will this fix the problem of laying on the clutch to get it to shift into gear? Also, was
anyone who has access.(2) Did you buy a reinforcement kit or make your
own? And (3)how thick of steel should be used? I called advanced Auto
but do not sell any push rods. (4)I dont think mine has an adjustable one
for sure?
Originally Posted by ArdWrknTrk
If, either the M/C is tearing the firewall or the clip in the eye of the master cylinder pushrod is worn out you will:
A) not get enough clutch release.
B) the pedal will not return all the way because the "assist spring" will not overcenter.
OK, I've got 21 years of receipts in the file and can't find it right now.
I DO know that at the time I bought both a adjustable clutch m/c pushrod and a flanged triangular plate, that came with two longer studs for the m/c and 3 bolts with self locking nuts to bolt it through the firewall.
My clutch release was non existent too.
I can take pictures in the AM when it gets light out....
Ask your Brother in-law to look at the pictures in this thread, and if he can help you make this part. (The ford part bolts on as shown) If not then buy the part from a dealer as suggested.
Does your push rod look like this, with a threaded section and a locknut in the middle?
If not, then NO it's not adjustable.
I hope this helps clear things up.
Old Sep 14, 2008 | 07:07 PM
  #57
MK_61701's Avatar
MK_61701
Question push Rod
Where is this push rod located, is it behind the clutch peddle near the firewall? I looked but could not find anything. Is hydraulic clutch make
a difference in using a push rod?
Old Sep 15, 2008 | 01:08 AM
  #58
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
In the preceding picture I am looking up behind the dashboard between the steering column and the gas pedal.
Old Apr 13, 2009 | 12:46 PM
  #59
artfd's Avatar
artfd
Exclamation
I have created a live action video of my 1983 F250 firewall/master clutch cylinder movement, which is probably what yours is doing also. It's on Youtube, click here to see it
Old Apr 13, 2009 | 12:58 PM
  #60
Tremclad's Avatar
Tremclad
Funny story, the green truck is dead. Now I'll be pulling all those reinforcement parts out because my new truck, a 1984 F150, is doing the same firewall separation thing.
