Cam swap
Old Mar 26, 2008 | 01:44 PM
9299Fords's Avatar
9299Fords
Cam swap
In contemplating a cam swap, I am looking up other parts I may need to change out at the same time. I have 140,000 miles on the 351. What have others found wear on? Timing chain and gears, cam bearings? Looks like I'll need lots of new gaskets. Comments?
Old Mar 26, 2008 | 01:58 PM
Conanski's Avatar
Conanski
You definitely should change the timing set when swapping cams, and depending upon the cam new springs may be necessary. Your motor has a flat tappet cam so it requires new lifters as well.
Old Mar 26, 2008 | 02:05 PM
9299Fords's Avatar
9299Fords
I'm going with your suggested cam (no one has disagreed or come up with a better one). With it I believe I won't need the 1.7 rockers or new springs? I'll add the lifters to the list. What about the cam bearings?
Old Mar 26, 2008 | 02:12 PM
Conanski's Avatar
Conanski
Must have been in another thread.. what cam did I suggest?
Should be no need for cam bearings, these are typically not touched unless you're doing a complete overhaul.
Old Mar 26, 2008 | 02:29 PM
9299Fords's Avatar
9299Fords
That would be Comp Cams 35-255-5 or Crane 444232. are they pretty much the same cam? I have the Comp Cam on the list.
Old Mar 26, 2008 | 02:37 PM
Conanski's Avatar
Conanski
OH yes.. I remember now. No they are not the same cam and I like the Crane for the reasons mentioned in the other thread. You won't need new springs with either cam, and even if you add 1.7 rockers to the Crane later on.
Old Mar 26, 2008 | 02:55 PM
9299Fords's Avatar
9299Fords
Thanks Conanski. Your comments on the 2-11 cam upgrade post answers most of my other questions.
Hutch17
Aug 30, 2013 08:52 AM
dakota-boy
Nov 22, 2011 10:20 PM
JHAM
15
Oct 15, 2009 01:45 PM
zoobiedoo
Aug 18, 2009 07:40 PM
fordeverpower
Aug 19, 2004 09:04 AM
