I have a 1969 F-100 with a 302 V8. My question is...with the motor mounts I have, is there any other engine that will fit with out changing the mounts?
A little bit of exhaust work for the 351w. It's a little bit wider, so a 302 y-pipe won't fit. Headers are different sometimes too. Sometimes they have to curl in a little more to miss the frame and such.
as weird as it sounds, you will probably get better mpg from 351w than 302. for some reason they are more efficient!! maybe due to torque curve, you don't have to get on it as much??
that said, I would swap in 351w with overdrive transmission.
