which products?
Old Mar 25, 2008 | 01:19 PM
bigdaddy54's Avatar
bigdaddy54
which products?
ive asked this before and ive done a search but nothing came up....my dad has a 99 7.3 and wants to chip it and exhaust it....im a 6.0 owner and dont know too much about the 7.3.....what tuners are you guys using and what exhaust? thanks ryan
Old Mar 25, 2008 | 01:22 PM
That_Guy's Avatar
That_Guy
Dp-tuner is the way to go, and I have a SS silverline an like it, MBRP is good but a little pricy.
Old Mar 25, 2008 | 01:23 PM
rhodester's Avatar
rhodester
DP tuners are by far the most popular from what I can gather on this sight. Also, I think most use a 4" exhaust. MBRP seems to be a pretty popular brand.
Wes
Old Mar 25, 2008 | 01:24 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
This is what I have for exhaust. Easy to install and sounds great. http://www.dieselmanor.com/exhaust/ford-ss-sgl.asp
I also have a DP-TUNER for my chip/tuner. You will see this combo in lots of sigs.
Good luck.
Old Mar 25, 2008 | 01:30 PM
bigdaddy54's Avatar
bigdaddy54
looking at the dp-tuner website there are a couple different options a pcm upgrade, a flash tuner, and a 16 position chip...which is better?
Old Mar 25, 2008 | 02:12 PM
jhand124's Avatar
jhand124
Most have the 16 posititon chip with varying amounts of files on the chip. 16 position=16 files or programs if you will.
Old Mar 25, 2008 | 03:08 PM
dannyboy7.3's Avatar
dannyboy7.3
I dont have either the chip or exhaust but I will probably get one of these once I can scrounge up enough money.
I am looking at the aluminized for 312 shipped with a tip
MBRP exhaust
or the aluminzed from MKO, Mfg #MKO99-03
MKO exhaust
I am also planning on getting a DP at some point.
Dan
Old Mar 25, 2008 | 03:25 PM
miller_feed
Dan, I would get the intake, exhaust, gauges before I would get the DP-TUNER. Truck will need to suck more air and will have to get that air out. Gauges are to keep an eye on the vitals of your engine while running. The EGTs can rise very fast.
Old Mar 25, 2008 | 05:21 PM
dannyboy7.3
Yeah, gauges are on the list too. Thanks for looking out for me. I already have the 6637, just need more posts to make a sig.
Dan
Old Mar 25, 2008 | 05:22 PM
bigdaddy54's Avatar
bigdaddy54
so it sounds like the dp tuner and mbrp 4"......now upon doing some more research is the afe stage 2 worth the money or is the 6637 filter mod adequate? seems like there would be a tremendous cost saving in the 6637 mod
Old Mar 25, 2008 | 05:42 PM
totin_tools's Avatar
totin_tools
I just got this new style AFE filter same as the 6637 and less than 100. https://www.ford-trucks.com/forums/7...ternative.html Best part is its cleanable.
Old Mar 26, 2008 | 03:09 PM
bigdaddy54's Avatar
bigdaddy54
so is that filter better than spending all the money on the intake kit or is that filter or the standard 6637 worth it?
Old Mar 26, 2008 | 03:50 PM
cvdenson's Avatar
cvdenson
With the mods I have, the Ford AIS and MKO 4" works pretty well. No issues with either one. And definitely go with DP for your tuning needs.
Chris
Old Mar 26, 2008 | 04:11 PM
IDPisan's Avatar
IDPisan
When a guy has been hit with the PMS bug he will usually start out with the 6637 because of the cost. It is easy to do, filters the air as well as the high priced filters, and leaves you more money to do other mods. It was my very first mod!!
HKusp's Avatar
HKusp
The 6637 is more than adequate according to most posters here (myself included) with the DP. You definitely have to get gauges and then you will probably want to go with a valvebody to firm up the tranny response. You will either do the VB before the DP in which case you can tell Jody that it is going in and he can tune you programs to the VB or you can do it the hard way(like me) and get the chip first. Wait a while, do the VB, then remove your chip and send it back to Jody to be re-burned for the VB, then re-install it.
csycowboy
Jun 19, 2013 03:40 PM
proudtruck
Dec 7, 2011 10:15 PM
A/Ox4
Jul 4, 2011 08:00 PM
northernz
Mar 8, 2011 01:33 PM
02GrayPowerStroke
Jan 20, 2007 07:46 AM
