Wind noise around driver door/window
Old Mar 25, 2008 | 09:53 AM
ronjeremy6's Avatar
ronjeremy6
i can hear a slight air leak around the top of the driver door on my 05 expedition. the dealer replaced the window regulator and made adjustments, but that didn't solve the wind noise issue. anyone know where to start?
Old Mar 25, 2008 | 11:03 AM
lbinh's Avatar
lbinh
Try making the door close tighter by bringing in the door striker. You need to loosen the two star/hex screws and tap the door striker plate in and re-tighten the screws and you should notice a difference in the door closing sound. It should sound more solid when the door shuts. That also helps when your door makes ticking noises. Hope that helps
Old Mar 25, 2008 | 01:42 PM
DMB's Avatar
DMB
Your door seal/gasket is not likely the problem. Don't mess with the striker adjustment unless you're sure the leak is around the door. The clue is that the dealer replaced the regulator. Chances are the window surround seal is not seated. Check the top rear corner. Mine likes to slide down from time to time, resulting in wind noise. Lower the window and pull the seal out from the rear of the door. Pull it up and make sure the gasket seats in the upper corner. That should cure the problem. Or, take it back to the dealer since they just replaced the regulator and tell them there's a problem.
Old Mar 25, 2008 | 01:52 PM
ronjeremy6's Avatar
ronjeremy6
yeah DMB, the noise is coming from the upper rear corner. but it was happening before i took it in for the regulator. actually, both issues were on the ticket and they only corrected the window and said that the wind noise "should" cease after adjustment of the regulator. i'll try rolling down the window and checking the seal tonight.
Old Mar 25, 2008 | 02:07 PM
DMB's Avatar
DMB
Also check/adjust as necessary the door seal gasket in the same manner (make sure the top rear corner is seated). I've seen the same problem with it sliding down a little. If adjusting both gaskets doesn't cure the problem, look elsewhere, including tweaking the door striker just a bit. Good luck.
Old Mar 25, 2008 | 02:35 PM
ronjeremy6's Avatar
ronjeremy6
^ now my door seal gasket IS in fact sliding down in comparison to the passenger door. i'll see what i can do about it.
Old Apr 3, 2008 | 04:47 PM
ronjeremy6's Avatar
ronjeremy6
an update:
i narrowed it down to the door seal gasket, because while i could hear the whistling i'd press the seal up tight and the sound would go away. had a new seal installed monday. only cost $78.
but guess what, drove at interstate speeds today and could still hear wind noise!! where do i look now?
Old Apr 3, 2008 | 06:13 PM
MisterCMK's Avatar
MisterCMK
Was it a cross wind?
Old Dec 7, 2008 | 10:44 PM
ronjeremy6's Avatar
ronjeremy6
i'm going to bump this, the noise is still there!! has anyone else had any experience with this?
Old Mar 15, 2009 | 08:27 PM
Rob_C's Avatar
Rob_C
All my doors are noisy, especially in a cross wind. I was looking at replacing all the door gaskets myself. Anybody got a source of supply?
Old Mar 15, 2009 | 09:54 PM
ronjeremy6's Avatar
ronjeremy6
ok, after the dealer replacing the door gaskets TWICE, i finally found the source of the wind noise. it's the window surround mounted in the door. you know, the piece your window follows and rest in while in the up position.
i picked the truck up on a thursday after they installed a new door surround ($161), and left for a road trip the next day. lo and behold, the noise was still there. so now i'm hell bent on finding the source of this noise.
i stopped at a pilot travel center and bought a roll of electrical tape. then i lined the entire door with tape. the noise was gone (of course). so then i started pulling sections off and listening as i drove *disclaimer* i'm not recommending you try this.
found the exact spot, then reapplied tape for the rest of the trip, basically so this noise didn't drive me crazy. when i returned home, i replaced the tape with a bead of RTV. worked like a charm.
what i had considered doing was installing some of those vent visors. the stick-on visors will cover the entire area where that trim meets the door. but see, i'm just not a fan of those vent visors. so i really hoped the silicone would work, and it did!
Old Apr 23, 2009 | 09:18 PM
ctmorgan's Avatar
ctmorgan
My 1999 expy was really noisy in the wind at the driver door. I tried adding double sided insulating tape to beef up the gasket to no avail. I traded it for a 2003 expy and have not had any problems with the newer one.
Old Apr 23, 2009 | 09:19 PM
ctmorgan's Avatar
ctmorgan
Read your last post. My 1999 had the visors and they did not help the problem.
Old Apr 16, 2010 | 03:14 AM
jes7's Avatar
jes7
window is warped in frame
1954oldred
6.7L Power Stroke Diesel
Aug 6, 2015 07:44 PM
feeo12
Feb 18, 2015 06:43 PM
My08F250FX4
55
Oct 12, 2011 08:14 PM
Hitokori
25
Feb 17, 2011 09:20 AM
xboxundone
1997 - 2003 F150
Mar 20, 2006 07:44 AM
