Source for an engine Master Rebuild kit
Old Mar 24, 2008 | 06:56 PM
turnrjr's Avatar
turnrjr
I spend most of my time at the 48-60 forum. Need some direction on where to buy a master rebuild kit for my 223 six. Just stripped the block. I will be bringing it and the crank to a local auto machine shop for inspection and boiling out. I expect it will have to be slightly bored and the crank turned to clean up. Once I know the over size dimensions I will order a rebuild kit. I searched google. Found Greenbay Parts World, Ron's Precision Machine and Performance Auto Parts. The kit I want goes from $680. to $869 at these vendors. Have any of you guys used these vendors? How was the quality and service? Any other supplier I should know about? Thank you.
Bob
Old Mar 26, 2008 | 01:57 AM
83Van's Avatar
83Van
It took some time and effort but for my recent rebuild I got most of the parts off eBay and from Rockauto. Wound up with the exact combo of premium valves, cam, bearings, pistons, gaskets, etc that I wanted and still came off at the same price as buying a pre-packaged rebuild kit with stock grade parts.. If you do want to go the "kit" route from a convenience standpoint I'd recommend Northern Auto Parts. Their kits are all quality parts and reasonably priced [about $300 for their master kit]. Plus everyone I've ever talked with there actually knew their s**t.
Whatever you do make sure to have your machine work done BEFORE ordering any parts to make sure you get the correct bearing and piston sizing.
Old Mar 26, 2008 | 06:30 AM
Harte3's Avatar
Harte3
Your machine shop might be able/willing to order a parts kit for you...check with them.
Natcox012
Dec 28, 2013 07:25 PM
NHSPRET
Jul 5, 2012 09:20 PM
turnrjr
Jan 8, 2009 07:21 PM
ccg711
Oct 21, 2008 05:42 PM
73XAFalcon
Jun 7, 2003 05:37 AM
