speedo cable help
Mar 24, 2008 | 01:29 PM
speedo cable help
i need to know how to remove it from the speedo.....i got the plastic clip off.....what now?
Mar 24, 2008 | 02:05 PM
You are supposed to pull plastic sleeve off the speedo head as you squeeze the retaining clip.
Mar 24, 2008 | 02:14 PM
Mar 24, 2008 | 02:27 PM
Wow I wish I wold have seen this last night I just ended up cutting it.
Mar 24, 2008 | 03:09 PM
Here is a short video......Not that it matters now, but for next time..
Mar 24, 2008 | 03:22 PM
wow, was that ever on tight
Mar 24, 2008 | 03:25 PM
It was maybe a little tight.
Mar 26, 2008 | 11:55 PM
Mar 28, 2008 | 01:40 PM
i sprayed some lithium grease in the cab end of it and i put it back in today and now it doesnt even move.....
Mar 28, 2008 | 01:41 PM
......b4 it just jumped around like crazy
Mar 28, 2008 | 04:45 PM
Sounds like you didn't line up the cable insert properly.
Mar 28, 2008 | 05:03 PM
you need to remove the gear at the end of the cable in the transmission and pull the whole cable out an regrease it
here's another pic of your truck
Mar 29, 2008 | 12:20 AM
alright ill try that tomorrow....do i need to use the white grease?....thanx for the pic
Mar 29, 2008 | 07:49 AM
Glad I came across this because in a few minutes I was going to go install my new speedo cable. I was wondering about the grease on the inside also.
Mar 29, 2008 | 12:03 PM
They make speedo lube made specifically for speedo cables and it comes in small tube.
