Sponsored by: Real Truck
Canopy brake light
Old Mar 24, 2008 | 10:31 AM
muncle's Avatar
muncle
Canopy brake light
Hi All, Where should I look to find out how to wire up a brake light on a conopy?
I've searched this sight quite a lot. Most info assumes its common knowlegde. Well, I'm mechanically challenged, so be nice!
I have a 99 F250 SC 4wd 5.4 with a gem top.
This sight is really great. It helped with my recent purchase of this truck.
Thanks for any help. Muncle
Old Mar 24, 2008 | 11:22 AM
Beerstalker's Avatar
Beerstalker
Go to the back of your truck and crawl underneath. Follow the wiring for your trailer connector back up behind the bumper. You should be able to locate a green wire that is labeled as CHMSL or Center High Mount Stop Light. That is the wire that you will tap into for your brake light on the canopy.
If you have an interior dome light you can tap into the black wire going to your trailer connector. That will be 12V+ whenever the key in the truck is on. That wire will not work if the key is in accessory or not in the truck. If you want to be able to turn on the dome light at any time, you will have to run your own wire from the battery back to the canopy.
Old Mar 24, 2008 | 12:03 PM
muncle's Avatar
muncle
Thank you kindly, Beerstalker. Awesome rig in your avatar. My truck doesn't even look like its LITTLE brother!
Old Mar 24, 2008 | 01:14 PM
msgtg's Avatar
msgtg
At least NOT YET....it's just a matter of time and money!
Joe
muncle
2009 - 2014 F150
13
Aug 31, 2009 03:46 PM
muncle
2009 - 2014 F150
Aug 4, 2009 05:37 PM
muncle
Mar 26, 2008 05:47 PM
muncle
Mar 20, 2008 12:03 PM
