Anyone know what that little critter is? It sits about dead center on the passenger side fender well, and when I turn my key I can hear it run- sounds like a small pump of sorts. I forgot to snap a pic, I'll try and get one tonight if it will help.
That's the solenoid relay for your starter. If you unplug that little snap on wire on the small post your truck won't start. It's an easy way to disable the truck in a pinch.
Yep -- normal. Diesels don't have a vacuum like gassers, so to run the climate control stuff (and SoTF 4WD if you have it), we need an electric vacuum pump.
Okay, good to know. Learn more about this truck every day on here!
