4" procomp
Old Mar 23, 2008 | 10:23 PM
mattr83's Avatar
mattr83
4" procomp
ive got an 83 f150 and i have a stage 2 4" procomp lift. i was wondering whats the best and CHEAPEST way to get 2 more inches out of it. thanks
Old Mar 24, 2008 | 08:07 AM
uncle.stosh's Avatar
uncle.stosh
Best way is to put the 6" kit in. Cheapest is to add some 2" blocks under your body mounts.
I personally don't believe in body lifts though, but it's up to you. If you do go that route, please do the right thing and raise your bumpers too.
Nothing worse than seeing a lifted truck with the big ole' gap between the body and bumpers.........
Old Mar 24, 2008 | 09:52 AM
ibleedblue1385's Avatar
ibleedblue1385
add-a leaf in the rear. you can get a pair 6" lift coil springs, or make coil spring spacers for the front.
Old Mar 24, 2008 | 11:04 AM
uncle.stosh
Coil spring spacers are never a good idea, and you must drop the center pivot brackets more to get your camber correct.
You can't just drop in longer springs.
Old Mar 24, 2008 | 12:08 PM
ibleedblue1385
if he got the 4" lift, it should have came with drop brackets.
Old Mar 24, 2008 | 12:10 PM
ibleedblue1385
Id like to add that, I have a 4" rough country lift on my truck. The axle drop brackets came with pre-drilled holes for a 4" and 6" lift. So you would simply have to drop it down the 6" lift hole. But who knows if there all the same...
Old Mar 24, 2008 | 06:32 PM
uncle.stosh
They aren't. Some have two sets of holes, and some don't.
Some have one set of holes and come in two different lengths too. It all depends on what he's got.
Old Mar 24, 2008 | 09:37 PM
ibleedblue1385
lets hope his brackets have an option for a 6" then...
Old Mar 24, 2008 | 09:41 PM
uncle.stosh
Keep in mind that 6" drop brackets put a LOT more stress on the crossmember. It is recommended that you bolt and weld them in.
I've seen quite a few crossmembers with stress cracks in them because of the additional strain put on them by the drop brackets.
Old Mar 25, 2008 | 09:05 AM
ibleedblue1385
Yeah i thought the same thing, so i welded mine.
Old Mar 29, 2008 | 01:17 PM
mattr83's Avatar
mattr83
yes my truck has the extra holes for the drop bracket
ap24
Oct 29, 2013 08:12 PM
378superduty33
6.7L Power Stroke Diesel
Nov 25, 2012 09:16 PM
jpcjguy
Jul 22, 2010 10:00 PM
WWBeast
Offroad & 4x4
Oct 28, 2007 09:20 PM
davelaboss
1983 - 2012 Ranger & B-Series
Oct 30, 2003 08:19 PM
