i currently own a 97 250sc 7.3td automatic 4x4 4.10s would like to change to 3.73 how much would fuel economy increase and how much work would it be to change the front gears
i would stick with what you have.
410GR is good for towing, its easy on your transmition and axles and such. and i would think a 3 73 GR would only be good for highway milage.
just my 2 cents
Mitch
I have 3.55 on '97 2X4 auto on the hwy, empty I can get 19-20 MPG
In town I get 16-18 MPG My right foot really controls the MPG
Towing my 5th wheel, which it does without effort and depending on the terrain, 10-14 MPG. If I get a long stretch of down hill, MPG pick up.
I realize that this was not the gear ratio that you were inquiring about but it may help in your decision.
You may also consider amortizing the cost of the gear change against the increase of milage. Your age and life expectancy could come into play as well.
With the auto I'd stick with the 4.10's (mainly for towing) and go with a GV over/under to get a higher OD. But it all depends on what you use the truck for....
3.73 to 4.10 isnt worth the work in my opinion, there is minimal change. the pain of swaping the front out is making it even worse, then the cost of parts weighs in as well.
I am not sure anybody makes 3.73 gears for the 10.25 sterling. If you do swap you would be best off finding somebody who has them and want to swap to 4.10's and just swap the whole axles. it will be much cheaper! Even just for parts it will take lots of miles to make any gains. A OD/UD unit are over $2k.
i knew ther ewould be a difference, i just never looked into it, i would imagine the ring gears are the same though since you can swap carriers. i really like the ability to put a locker in the dana 50 now, another addition to my ever expanding list
