got a 73 f350 camper special 390 auto.i want to get ride of the points and go electrical ing.what do i need to do?also the brake petal is very stiff takes alot of effort to stop ,
For sure go with the duraspark and get the adaptor and the large cap. Get a good cap (not black as they are made with carbon black and carbon tracking is bad) with moulded in brass termals. Go with the TFI coil and the wire adaptor, gap plugs at 45 and you can have more useable spark that a hei dist.
A heavy vehicle like that needs a very precise advance curve to avoid engine damaging detonation.
If you decide to get a new distributor, consider our custom curved Duraspark Distributor built with our new Full Length Oil Impregnated Bronze Bushing. The full length bushing improves timing stability and spark scatter. If stock appearance is not an issue, take a look at our one piece D.U.I. Distributor. Whether you choose the Duraspark or the D.U.I., we curve each on a distributor machine based on your engine combination. Please see them at:
