6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Removing Dpf
Old Feb 16, 2012 | 11:28 AM
Stinkweed14's Avatar
Stinkweed14
Removing Dpf
How difficult is it and how do i do it. Can I do it with basic tools
Old Feb 16, 2012 | 12:47 PM
smotrs's Avatar
smotrs
About 2hrs give or take for the exhaust. Yes, basic tool set will work, probably need a couple long extensions and a universal joint for one of the bolts/nuts.
Also, spray all attachment points with PB Blaster a day before, your life will be much easier. Keep in mind the DPF/CAT system can way close to 100lbs, so have something supporting it other then your face when it comes loose.
Old Feb 16, 2012 | 12:52 PM
Stinkweed14
What about the sensors. Can they just be unplugged
Old Feb 16, 2012 | 01:20 PM
LJC's Avatar
LJC
They can be just unplugged (tape the connectors to protect and fix them so they will not be damaged) if you have a tuner that allow not having those sensors.
Old Feb 16, 2012 | 06:39 PM
aquaman's Avatar
aquaman
If you have an air wrench or drill/driver, you can drop off the DPF-only in about 20min.
The nuts holding the DPF to the CAT are slightly undersized so they won't spin off by themselves and it gets tiring doing it with a socket wrench.
I had a jack under mine to hold it while pulling it off.
Don't bother with trying to pop off the rubber hangers. Completely remove the hanger piece from the frame by taking out 3 nuts. It's a lot easier.
Old Feb 16, 2012 | 09:03 PM
BROWN DOG KTM's Avatar
BROWN DOG KTM
IF you remove the Exhaust Sensors,
BE SURE TO USE A FLARE NUT LINE WRENCH or you will strip the nuts
Mine was Super TIGHT
Old Feb 17, 2012 | 09:06 AM
Harley250SD's Avatar
Harley250SD
I can vouch for that advice. Just did the delete it last week and man that exhaust sensor is a bear. I screwed it up but good with a wrench and then even some vice grips and didnt get it off. Ended up just leaving it in and storing the DPF/CAT assembly in the shed. Wished I'd read about the rubber hangers too. That took a while to get them off. I didn't realize you only need one of the hangers when you put in the new pipes.
Use the PB Blaster liberally on everything and let it soak in. When all the clamps are loose, use a rubber mallet to bang on the muffler to separate the pipes without damaging the muffler. Support the DPF with jack stands as it weighs a good amount.
Good luck!
Old Feb 17, 2012 | 09:32 AM
Brandon D's Avatar
Brandon D
Lead Foot User
That's funny, I seem to remember taking the time to warn you about the rubber hangers before you did your delete. I guess you skipped that part when reading. They are a real bitch if you try to fight them off without completely removing them, but I guess you know that now.
Old Feb 17, 2012 | 10:48 PM
smotrs's Avatar
smotrs
BTW, what size is this for people looking to do it and wanting to pick up a line wrench? Might help someone.
Old Feb 17, 2012 | 11:07 PM
BROWN DOG KTM
13mm & I forget the other size
Old Feb 18, 2012 | 11:00 PM
RM2738's Avatar
RM2738
I used an 18" flat bar and the rubber hangers slid right off.
250_newf
Oct 11, 2018 02:15 AM
ATE88
19
Jan 17, 2018 06:22 AM
Harley250SD
21
Feb 14, 2012 04:56 PM
RomerB2
Bronco II
Feb 22, 2008 03:21 PM
MickeyP
Garage & Workshop
Feb 27, 2003 08:04 AM
