Exhaust probe.
Old Mar 22, 2008 | 10:46 PM
officer131's Avatar
officer131
Question Exhaust probe.
Just installed the pillar gauges in the X. Reading the directions and suggestions on the board here. Were would I find the "R" on the drill bit for the probe hole. What size would that be ex: 1/4 or what?
Old Mar 22, 2008 | 10:56 PM
Izzy351's Avatar
Izzy351
It would be where it normally is. Here are the details on an R bit:
8.6106mm -- .339" -- R -- 1/8"-27 NPT
Check out the size chart here (R is quite ways down the list):
http://bobmay.astronomy.net/misc/drillchart.htm
Here's another good page:
http://www.sheldonbrown.com/tooltips/taps.html
Old Mar 22, 2008 | 10:59 PM
IDPisan's Avatar
IDPisan
If you are going to tap it the size is a 21/64 drill bit. Start smaller and work your way up use a shop vac to suck out the shavings.
Hope this helps!
Old Mar 23, 2008 | 01:02 AM
hosemandc's Avatar
hosemandc
I used a 21/64 and it works great. Drop the front driveline and save yourself some trouble. You can get it done with out dropping it but what a hasle. Be careful not to tap too far.
Full Throttle
Mar 19, 2009 11:50 AM
JohnAW
General Automotive Discussion
Oct 9, 2006 03:15 PM
Bob Ayers
Electrical Systems/Wiring
32
Aug 22, 2006 11:23 AM
XxfirmanxX
Mar 20, 2006 10:23 AM
