SROD gyrations
Old Mar 22, 2008 | 09:56 PM
Dobbinicus's Avatar
Dobbinicus
SROD gyrations
Good evening fellas,
Can anybody comment on how much "slop" there should be in the output shaft/slip joint connection on an SROD transmission connected to a one-peice drive-shaft? In other words, where the slip-yoke of the driveshaft enters the tailshaft of the SROD transmission? While trying to isolate a driveline vibration today I found that I can move the joint around in the tailshaft quite a bit. I'd say it deflects as much as 1/4 inch in any direction. I would think that there should be zero deflection or slop.
Old Mar 22, 2008 | 10:47 PM
85e150's Avatar
85e150
That's way too much. Barely noticable is the amount I've seen.
Old Mar 23, 2008 | 08:17 PM
Dobbinicus's Avatar
Dobbinicus
That's what Id' think as well. Thanks for the input!
banjopicker66
Jan 8, 2016 08:20 AM
reamer
36
Apr 8, 2014 07:17 PM
Freightrain
Dec 23, 2013 04:09 PM
Buck268
2009 - 2014 F150
Sep 28, 2013 09:48 AM
mr_muldoon
1978 - 1996 Big Bronco
Aug 31, 2003 09:28 AM
